New project 14ft Meyers V Hull
perchjerker
Post by perchjerker » 28 Feb 2016, 19:40
Hey gang. I have had this boat for 3 years and its time to give it a face lift and make it more comfortable for me to use.
I do have a basic game plan which I will outline for you, but I have a few questions first.
They are about the outside of the hull. Its of course dull ugly and faded.
I would like to paint it, after fixing some cosmetic issues which I am going to post some pics of
the hull is very sound and does not leak a drop.
the first pic is an overall shot
the next pic is what I am wanting to fix if possible, There are some what I call creases, I dont know if they can be fixed without a lot of extensive work or not. I have a gut feeling I will just be living with it
What are my options with this? Just live with it? If thats the case I am ok with it but I figure if I am going to try to fix this up I would like to address it if its not too much
I dont want to make a career out of refinishing the hull but I would like it to look a bit nicer, maybe clean up the bottom and paint above the waterline? Or should I paint the entire hull?
What are your thoughts?
thanks!!!!
perchjerker
Post by perchjerker » 01 Mar 2016, 08:56
I was hoping to get a little input on this
I think what I have decided to do is just to paint it above the rub rail to dress it up a bit and just leave the bottom as is
Johnny
Post by Johnny » 01 Mar 2016, 09:12
Perch said: I don't want to make a career out of refinishing the hull - but -
LOL yeah, "but" if you start addressing structural issues, it will be like Whack a Mole.
something else will pop up. and you will spend more time doing cosmetic work than
having fun on the water.
and yes, those wrinkles "can" be smoothed out to where they are not quite as noticeable.
A bare shiny hull will show up imperfections far more than a painted surface. Plus, you
can use body fillers such as Bondo under the paint for a very slick and smooth surface.
Paint provides some form of protection from the corrosion factors - but - can also trap
corrosion in the seams, rivets, and such. So it is a judgement call within your skillset
as to what you will be using the boat for - - - fishing, hunting or family fun ?
Pros and Cons on each end.
your boat - your call.
This is my 1959 Crestliner. It has been very well taken care of in its lifetime.
but, there are many holes, dings and divots that have been fixed with body
fillers, epoxy, etc. and covered with paint. Using the "500-30" rule, it looks awesome!!
what is the 500-30 rule you ask ??? LOL at 500 feet away and 30mph, it looks great !!
http://www.tinboats.net/how-to-build-a-transom/
http://www.tinboats.net/varnish-vs-polyurethane/
All about Primers = http://www.tinboats.net/primer-and-paint-basics/
Paint, Thinners and Applications = http://www.paintingforpainters.com/
1959 Lone Star Malibu 14'
perchjerker
Post by perchjerker » 01 Mar 2016, 09:18
thanks
that's why I decided to just leave the bottom as is and just paint it above the rub rail. that's where most of the ugly stains are anyway from old oar lock hardware, and other things the original owner screwed into the hull
that looks like a crack above that 2nd screw for the oar lock but its just a scratch
perchjerker
Post by perchjerker » 02 Mar 2016, 11:26
I made some progress in the planning.
I am going to cut the middle out of the center bench. In its place I am going to make a frame resembling a ladder with uprights on each end. These will attach to the sections of the center bench remaining on the boat.
I have this for framing material. Its Bosch Rexroth structural aluminum. I work in a test lab and we use this material to build test benches. When the benches are scrapped, the stuff is usually just sent to recycler, so I grabbed a bunch years ago and its been sitting in my garage ever since
This stuff is very strong and will work great to replace the support that the center bench provided.
And since I have a lot of this, and also the fasteners used to connect it at right angles, I may end up just framing the floor with it.
Here is a sketch of my plan. The gray bars represent this framing. I may end up placing pieces running down the center as well.
I will replace the floatation by putting it in the side compartments. Not sure on the seating yet, but it will be typical placements.
Green areas would be decking/storage areas
any thoughts on my ideas so far?
thanks
Johnny
Post by Johnny » 02 Mar 2016, 11:48
wow, you are so lucky to have the 40mm framing metal !!
you can have double the strength of the angle twice that size.
good layout so far - keep up the good work.
have you decided on a motor yet ? Tiller or Remote steer ?
Ictalurus
Post by Ictalurus » 02 Mar 2016, 12:14
Perch,
check out the lowe link in my sig. i took the middle seat of a v-hull as well, works great.
perchjerker
Post by perchjerker » 02 Mar 2016, 12:36
thanks guys!!
Johnny I have this 9.9 tiller) it runs like a sewing machine. It came with the boat. I have had it for about 3 years now
Ictalurus yours look great! Gives me some good ideas. There are so many builds here its hard to sort through them all!!
One thing I need to figure out how the best way to attach the framing to the boat is. It does not have a lot of ribs. I will attach it as good as I can to the ribs I do have.
I plan on starting on it this weekend, it has been in my pole barn at my cabin. I towed it home this past weekend. Now its full off snow lol. But that wont last
thanks
Texas Prowler
Re: New project 14ft Meyers V Hull
Post by Texas Prowler » 02 Mar 2016, 12:49
Really nice layout man. If you have any left over send it my way[WHITE SMILING FACE]
Sent from the dust in front of you!
perchjerker
Post by perchjerker » 03 Mar 2016, 08:27
Texas Prowler wrote:Really nice layout man. If you have any left over send it my way[WHITE SMILING FACE]
thanks Tex!
I am borrowing a Dewalt chop saw from work to cut the supports, this stuff is pretty tough and the chop saw makes it real easy to do.
I am going to start on it Saturday, its still full of snow but I will get it thawed out and in the garage!
Texas Prowler
Post by Texas Prowler » 03 Mar 2016, 10:39
Sounds like a plan. I'm limited to my garage due to the driveway being sloped.
perchjerker
Post by perchjerker » 03 Mar 2016, 18:14
I decided to flip the layout of the side compartments. Reason being I will have more legroom running the tiller from the right side.I have been getting expert tips from Lyle (Schukster) as I am using his build as model for mine. He pointed this out to me and I am glad he did!
He did such a nice job on his build!!! http://forum.tinboats.net/viewtopic.php?t=39912
For fun I just took a pic of it as it sits in my driveway now. You can see some of the alum strut material as I was sizing it up
Come Sat it will be defrosted and in the garage! Then the work shall commence!!!
Fishfreek
Post by Fishfreek » 03 Mar 2016, 18:31
What's all that white fungus stuff all over everything? Looks like a good platform to start with.
Fish fear me
Women love me
But I sit here all alone eating peanut butter sandwiches
perchjerker
Post by perchjerker » 04 Mar 2016, 18:20
ha
just got back from the car wash, all the fungus is gone!
While I was backing it in the driveway, a guy drives by and sees me backing in, slows down and gives me the big 2 thumbs up!
thought that was cool....
perchjerker
Post by perchjerker » 05 Mar 2016, 14:37
I made some progress this morning. I am working on the floor framing, nothing is secure yet, just laying it out.
I do have an issue, that carpet is glued to the floor. I hope I can get it out with a heat gun but mine must be at my cabin in my pole barn, so I am going to borrow one from my work on Monday and give that a try
