It is currently 19 Sep 2014, 13:49
 Page 1 of 2 [ 21 posts ]  Go to page 1, 2  Next
PostPosted: 25 Oct 2009, 20:44
Hey guys, I've been thinking about putting in a live well and thru transom pump to fill it and drain it. I am however a little leery about cutting a hole in the boat. Any suggestions?
If I were to mess something up, how hard is it to fix the hole? Are there any alternatives that you would suggest? I am new to this forum and have not done any projects or much handy work but I am excited about working on this boat mod.
PostPosted: 25 Oct 2009, 21:43
good question i had the same and will soon be building a baitwell for my boat. i read an article about a guy who took an igloo cooler (like the ones w/ the little spout for dispensing water) and put a bulkhead in the side of it near the top and used some vinyl hose w a bilge pump at the end. he just put the hose over the side so the pump was in the water and used that to fill the cooler w water. then he had another bulkhead and hose out the other side of the cooler running off the other side of the boat as a drain. thats prolly the easiest most portable system ive seen but i think the wiring would be a little janky. im thinking about building a little tank and putting it in my center bench. all you need to do in order to go through your hull is drill your hole and use a bulkhead w some sealant to make it water tight. if you need to fix just remove bulkhead get a small square of alluminum and use 5200 sealant to patch the whole. if im wrong on any of this please someone chime in.
matt
PostPosted: 25 Oct 2009, 22:15
You could do it that way, but they make thru hull livewell pumps, eliminats the need for thru hull fittings. Your going to have to cut a hole anyway, check around wal-mart, I have seen them there, around $40.00 make sure you dont cut your hole to big in your hull, and use a good sealant like 5200. Piece of cake!
PostPosted: 26 Oct 2009, 06:42
Thanks guys.
What would you use to cut the hole? My aluminum is very thin so I know I wouldn't need much but I just wanted a clean cut.
PostPosted: 26 Oct 2009, 08:16
You could use a hole saw - I have used one on my boat for installing lights etc. You can buy individual ones or get a kit with several at Lowes or HD. I think they come in 1/8" increments. The teeth may fill with aluminum but it is pretty easy to clean that out with a nail or needle-nose pliers.
My Tracker 1448 Grizzly project
viewtopic.php?f=21&t=13758
My Lowe 1236 project
viewtopic.php?f=21&t=9712
Image poison...poison...tasty fish!
Tracker Grizzly 1448 / 25hp Mercury 4-stroke
Sportsman 14' / 40hp Johnson
Elie Sound 12' kayak
Online
PostPosted: 26 Oct 2009, 18:13
If I did not want to drill a hole, would the pump and drain work if I ran the tubing over the back of the transom and down the outside back end of the boat?
PostPosted: 26 Oct 2009, 18:35
No, not unless you throw the pump overboard, and then pump the livewell out by putting the pump inside of it, Just srill a hole with a hole saw, youll be happier in the end...
Bustin' Bass
My Second Tin, Not my last as I don't like it already!
My first Tin
PostPosted: 27 Oct 2009, 12:44
I drilled three holes in my aluminum boat transom for a livewell and bilge pump. One hole to fill the livewell, one drain it, and a third for the bilge pump. I used aquarium tank sealant to seal the fittings. Get a bimetal hole saw kit and you'll be fine. I think the fill and bilge pump holes were 1" and the drain hole was 1 1/4", maybe 1 1/2". Check my signature for my boat /trailer remodel project. I haven't had any problems and my boat doesn't leak. I haven't even used my bilge pump yet. I also converted an old Coleman cooler into a livewell. Its all in my build thread, including some detail pics of the livewell and the transom.
Drain hole
download/file.php?id=5898&t=1
Livewell pump- since this picture the tube has been cut, screen installed, and the sealant cleaned up.
download/file.php?id=5899&t=1
Inside view
download/file.php?id=5900&t=1
HOI Crappie Club
Where family and friends come to compete for a little more than bragging rights.
'67 14' Alumacraft
'57 Model FD11 18-hp Johnson Seahorse
'04 Trailblazer I6 4x4x4
PostPosted: 27 Oct 2009, 21:12
Thanks for the replies guys. Hanr3, thanks for the pictures. I plan to dig into your project a little deeper. I am assuming that you can only drain the livewell after you pull the boat from the lake..right? I saw that your drain hole is below the water line...Is my assumption correct? Thanks,
PostPosted: 28 Oct 2009, 08:16
I fill and empty my livewell with one 800gph bilge pump that I toss over the side of the boat to fill, then pop it in the livewell to empty. I haven't drilled any holes yet because I'm still waiting to get my actual livewell in...
Fisher 1860AW... New Build under construction
1546 Xpress -- SOLD!!
PostPosted: 28 Oct 2009, 10:52
The drain hole in the transom is below the water line, however I'll put the overflow tube (plug) in before I launch and that keeps water out of the livewell until I am ready to use it. The top of the overflow tube is well above water line. Yes there will still be water in the drain line, however if I dont use the livewell that water will drain as I trailer the boat. When I catch fish and fill the livewell the plug is already in. On shore I'll take the fish out and pull the plug draining the livewell. I do open the livewell lid while the boat is parked so it will dry and not get moldy.
HOI Crappie Club
'67 14' Alumacraft
PostPosted: 05 Nov 2009, 10:00
Hanr3,
Sorry, I am still alittle confused on your last post. If you have time, can you clarify? After your post I looked at your pictures. You said that the the top of the overflow tube is well above water line. I could not see the overflow tube above the water line in the pics. It looks like everything on your transom pics were below the water line. Maybe I could understand it better if I got a feel for how your whole system works. I guess I am still in the dark a little on how everything would work from beginning to end. I know this is going to be a really stupid question to you, but I am so completely new with all of this.."What is the overflow tube used for and how does it work?, "I am assuming this is what is used to fill the livewell..?". I also noticed ironically, that I think I have the same exact boat that you have.
PostPosted: 05 Nov 2009, 10:10
bottomdweller, this is how a livewell works
You have a livewell pump at the transom of your boat, below the waterline (you gotta get water somehow ;). This goes to the intake of your livewell - it can be above or below the waterline... most times you see it above the waterline as a spray bar which forces water down and as the tank fills, it adds oxygen (you'll see all the little bubbles coming up). That is pretty much the fill up process.
Next is areation. There are a few ways you can do this, but I'm just going to keep it simple so it helps you understand... You have another livewell pump at your livewell. The strainer will be inside the livewell, that motor outside. The hose coming off the motor will circle back around to above where you filled the water so that is can recirculate the water adding more water and ridding of carbon dioxide.
Then I think the way Hanr3 has his drain/overflow is one shot. But if I'm wrong sorry, I didn't take the time to go back and look. You have a drain hole in the bottom of the livewell to let the water out. Well, instead of putting a plug into it, you put an overflow tube. This tube catches and drains any water from overfilling or if you accidentally leave your pump on too long. It basically is a safety catch so that you don't fill your boat up with water.
To drain it, when you pull out of the water and while on the trailer, you pull the overflow tube out or drain plug in the livewell, and then take the plug out of whereever it exits the boat and voila, water gone.
PostPosted: 05 Nov 2009, 11:08
The way russ described it is one way to setup a livewell. It takes two pumps and would work great. Especially if your in salt water and cant pull water out of the lake you still have a method to recirculate water..
Another option is like this.
You have a pump out the transom below the waterline. This pumps water to the spray bar above the "livewell waterline" This will fill the livewell and the spraybar will mix o2 with water.
You then put a overflow in the side of the livewell. The overflow drains out the side of the boat. You will want to drill the overflow in the livewell an inch or two below the top of the livewell and the hole in the boat 1/4" below the livewell hole. The drain will also be larger then your pump line. If you look at this kit. http://www.cabelas.com/p-0001659012937a.shtml you will see how it works. The 3/4" hose runs from the pump to the spray bar. The 1 1/2" hose runs out the side as an overflow.
now, you turn on your transom mounted pump and fill up the livewell. Then you adjust the spray bar so that it only flows as much water as will dump out the livewell overflow. Then you can run the pump all day long if you wanted and it will just dump out the side. The best option is to put the pump on a timer so that it runs for 1 minute every 5 minutes or something to that effect. You can find a bunch of different options on live well timers.
Finally you put another drain in the bottom of the livewell towards the back of the boat. This drains out the back of the boat right next to where your pump is. It can go anywhere you like really, but thats an easy place to put it. When we did my bud's 14' alumacraft we didn't have room to run the drain out the back of the boat so we went straight out the bottom below the livewell. I used fittings and hose for this that you can buy individually and so its not difficult to piece it together. I am not sure if they make different size fittings or not so if you go this route then you can grab a boat plug from the shelf and make sure it will stick into the fitting. I am pretty sure they are standard sized.
When you are using the livewell you put a standard boat plug in the bottom drain. When you are done with the livewell you pull that plug out of the bottom of the livewell and it will drain.
With a setup like this you are brining fresh water into the boat from the lake so you don't need to run a recirculating pump. Put your livewell pump on a timer and its a done deal.
Now to be honest, I have my livewell setup like this but I am thinking about changing the setup when I put my boat back together. I am thinking about adding a recirculating pump. I am thinking about adding a second smaller livewell to my boat. I want to be able to seperate my catch from my bait. I now just toss my minnows and leaches into my livewell. I am thinking about adding a new pump that will draw out of the bottom of my current livewell and spray into a new smaller livewell. The overflow from the smaller livewell will flow back into the larger one. I don't quite know how I will figure this out but I am thinking on it.
I also did a quick search on recirculate vs timer/fresh water method. Here is something I didn't consider.
Livewells can be operated to pump in fresh lake water or
recirculate livewell water. A recirculating system is es-
sential to provide aeration when the boat is on plane, when
the boat being trailered, or when you are controlling livewell
temperature (see below). If your boat does not have a re-
circulating system, add one. Brands of boats differ, so be
sure you understand the livewell control settings for fresh
water intake and recirculation.
On plane and on trailer are some valid reasons to have a recirculate pump. This is a darn good read.
Keeping bass alive.
http://tinyurl.com/yjlor8g
It is making me rethink the recirculate method.
LEFT is right! The reel handle is properly oriented when it is on the left side.
PostPosted: 05 Nov 2009, 11:20
Why do you have to pull the boat out of the water to drain it? Even if the drain it below the water line the water will still drain. It will be a wee bit slower then if the drain was above water line, but it will drain.
Sears Gamefisher 1436
9.9hp Johnson
34 lbs. Trolling Motor
Users browsing this forum: acabtp, chickenpimp, Google Adsense [Bot], Knee Deep, kofkorn, overboard, timberwolves and 62 guests
