It is currently 19 Sep 2014, 21:51
 Page 1 of 1 [ 4 posts ]
PostPosted: 18 Mar 2010, 07:06
Do a search on jackplates,theres post on the subject.
A prop motor can only be brought so high & as stated your prop will start to slip.But more important is your water pickup.Starve the motor of water & you'll fry your motor.Jets I believe will go in
6" of water wide open on plane but the best a prop might do is 8 to 10 inches.
Craig
Be Who You Are
And Say What You Feel
Because Those That Mind ....Don't Matter
And Those Who Matter....Don't Mind
PostPosted: 18 Mar 2010, 09:38
On my 1436 jon I have a TH Marine Mini-Jacker. With the set back from the jack plate I can run with the anti ventilation plate 1 to 2 inches above the bottom of the boat.
PostPosted: 18 Mar 2010, 18:00
Check out viewtopic.php?f=3&t=10425 I haven't had any problems with mine. Over 5" of set back and the cavitation plate is 2" above the bottom of my boat. I've heard (don't hold me too this) that you can raise your cavitation plate above the bottom of your boat a 1/4" - 3/8" for every inch of set back as a general rule of thumb without low water intake.
Even with a low water intake, your going to have problems in a true 6" of water. I've had 3 boats with low water pick ups and hydraulic jackplates and couldn't run in a true 6" of water. I can push the boat you see in the link above and possibly get on plane using the pods in 12" of water. I normally just Idle or TM to deeper water. I've busted to many props and shafts. I also do not like sucking up all the mud and sand into my motor.
PostPosted: 18 Mar 2010, 18:47
boater1234 wrote:
sweet that is what i'm talking about.do u get any slip at all?
No. It gets out of the hole fast and is fast. No gps yet.
Users browsing this forum: Bing [Bot], chickenpimp, great white, onthewater102, overboard, WaterWaif, Y_J and 67 guests
FishFinderMounts
