It is currently 20 Sep 2014, 11:57
 Page 1 of 1 [ 10 posts ]
PostPosted: 11 Jul 2010, 11:48
Your not going to have corrosion problems just because the paint wore off. (Its Aluminum)
PostPosted: 11 Jul 2010, 11:53
If you want it to last it has to be marine paint, or type of auto paint for it to hold up if its on the outside of the boat. You could try rustoleum as it will stop rust, althought aluminum usually doesnt rust but I am not sure how it will hold up in the water.
14' 77 Starcraft Seafarer
http://www.tinboats.net/forum/viewtopic.php?f=21&t=14725
PostPosted: 12 Jul 2010, 21:04
boater1234 wrote:
I know aluminum does not rust all the way through but it does get surface rust on it as i have seen plenty of aluminum boats with surface rust on them.
Don't think I'd call it "rust." The only time aluminum really 'rusts' is when exposed to liquid Mercury. Otherwise, it is just minor oxidation, and it is better at protecting the boat than paint is.
Aluminum is actually a highly reactive metal, with very poor qualities. In fact, most of the properties of aluminum make it virtually unsuitable for marine use. But, what makes it usable is the fact that it begins to oxidize within seconds of being exposed to air. It is this thin layer of aluminum oxide that makes aluminum the wonder metal. The oxide melts at around 3 times the heat that the aluminum does, which is why we have to TIG weld it on AC, and not DC (the AC current breaks the oxide layer up).
Who is John Galt?
Lowe 1756 tournament electric only boat
G3 1756 tournament electric only rig
Tracker 1448 aft bench storage
Tracker 1754 Deck Extension
PostPosted: 13 Jul 2010, 09:32
You should complain to the seller about the scratches. I had similar scratches on my Tracker when I bought it. I complained about it and they gave me a $100 Basspro gift card, no questions asked.
“There’s a fine line between fishing and just standing on the shore like an idiot.” ~Stephen Wright
The Livin Large Project - viewtopic.php?f=21&t=14160
PostPosted: 13 Jul 2010, 11:10
nothing will match, easyer leaving it a lone, or painting the whole thing.
My 1237 Grumman Jon Conversion
viewtopic.php?f=21&t=12778&start=0
Harbor Freight Trailer tips:
viewtopic.php?f=49&t=13389
PostPosted: 13 Jul 2010, 13:58
OOPS, it was not PPG, my bad.
Post removed with paint code. See Page 2
Last edited by ihavenoideawhattoput on 13 Jul 2010, 14:54, edited 2 times in total.
Death on a Stick
PostPosted: 13 Jul 2010, 14:14
http://carpaintonline.com/
Sells PPG paint in tough up cans
Death on a Stick
PostPosted: 13 Jul 2010, 14:27
I don't think that their standard flat OD green jon boat paint is PPG paint like you listed, but I could be wrong.
Paddle faster... I hear banjos
PostPosted: 13 Jul 2010, 14:53
OD Green Paint direct from Alumacraft (NON PGP) my bad
ARKANSAS
1329 N. 10th St.
P.O. Box 189
Arkadelphia, AR 71923
870-246-5555
Part Number: 2-30-008-3030 Price: $59.00 Per Gallon
Part Number: 2-30-007-3001 Price: $15.00 Per Can
The Dealer should give you a spray can to fix any scratches.
Death on a Stick
PostPosted: 13 Jul 2010, 16:31
Quote:
...The Dealer should give you a spray can to fix any scratches.
Absolutely. Tracker hooked me up with a can when I owned my Tracker PT175. The "Electric Blue" color as it was called would have been a real pain to find anywhere else.
Users browsing this forum: earl60446, erictetterton, great white and 48 guests
AirboatCoatings
