It is currently 23 Sep 2014, 14:21
bassboatseats
 Page 1 of 1 [ 8 posts ]
PostPosted: 13 May 2011, 00:28
Ok guys just got my new to me boat 16' mod-v aerocraft alum boat, the transom is for a short shaft motor....I know everyone is going to say get a short shaft motor... that is not an option right now...I went out there tonight and measured the transom from the bottom of the boat to the top of transom it measured 16" I know a short shaft motor is 15" and long is 20".....I guess what I am trying to say is should I build the transom up with some wood and through bolt and alum plat with alum square to get the right hight kind of like this
or something like this
I also saw a plate like this online which I thought was a pretty good idea and would work well
http://shop.torresen.com/ships_store/?p ... ionid=2649
I will be putting a 57 evinrude 35hp on this bad boy, the transom is rated for 40hp...
here are some pics of my transom as of right now....
http://i596.photobucket.com/albums/tt50 ... 5625-1.jpg
http://i596.photobucket.com/albums/tt50 ... 5604-1.jpg
http://i596.photobucket.com/albums/tt50 ... 5532-1.jpg
Thanks for the input.....
PostPosted: 13 May 2011, 07:42
I would use a mini-jacker plate, see pics below. Most mount the jacker higher so you don't have use the piece of wood as a riser. You want your cavitation plate on your motor to be just about even or a little higher than the bottom of your boat depending on how shallow you want to run. Don't get it too high, because your water pump might not pick up water, then it would overheat. Do the ol trial and error thing, go up then down to find the right place for your motor, good fishin, jus' sayin'
A BAD DAY ON THE WATER IS BETTER THAN A GOOD DAY AT THE OFFICE ANY DAY OF THE WEEK. MY FAVORITE TWO DAYS THAT START WITH A "T", ARE, "TODAY & TOMORROW".
PostPosted: 13 May 2011, 09:18
I have the mini-jacker too. Works great, very easy to install and costs about $75 at Basspro.
“There’s a fine line between fishing and just standing on the shore like an idiot.” ~Stephen Wright
The Livin Large Project - viewtopic.php?f=21&t=14160
PostPosted: 13 May 2011, 14:31
OK so u guys saw the pics to my transom right???? If I put new wood where it needs to be, and then put this pretty much measure through bolt it and mount motor right..... My transom will be ok with it sticking off the back a bit??? If everything will work I might just go the mini-jacker way.....
Thanks for the input guys
PostPosted: 13 May 2011, 15:06
If you like you can stop by and check out my set up.
PostPosted: 13 May 2011, 15:16
Do the mini jacker! it works great. I have a longshaft Merc 25hp on a 15" transom, and even my minijacker is mounted high. I have hit logs, bounced over stuff, ran aground, all several times without any problems. Its solid!
PostPosted: 13 May 2011, 19:29
That sounds like a plan? I might even bring the boat and the motor and u can possibly help me, since I am new to this boating and motor mountin thing lol
PostPosted: 13 May 2011, 19:43
That would be cool. We can put it the fox river.
Users browsing this forum: Chance174, DrNip, kofkorn, Lowe 2070 CC and 63 guests
AirboatCoatings
