It is currently 19 Sep 2014, 17:50
blackhawkcustombaits
 Page 1 of 2 [ 16 posts ]  Go to page 1, 2  Next
PostPosted: 18 Jun 2011, 22:28
Hey guys I got the front and middle seat done on my 14' richline and am contemplateing the rear seat and or deck area. I have a 53" back bench and plan on a fixed seat/post attached to a slightly raised(3") deck. I have been deciding on the fixed seat/post to be centered or offset to control my 9.9hp engine better. either way there does'nt seem like theres enough space back there to move my 6' 3" frame around. offset or centered, short fixed post or 13" fixed post, what say you? :roll:
PostPosted: 18 Jun 2011, 23:18
Centered, 13". I needed to make this same decision about a month ago. I asked a local jet boat builder and he said to center my seat because a tiller steer has the tiller off to one side of the motor to allow the seat to be centered. Facing forward, you would use your left hand, tiller handle is on the left side of the motor. Say you offset the seat to the right, if you have to push the tiller away from you with a seat off centered, you have to lean to far that way. Centered, you can turn it either direction without leaning. I followed his advice and I'm glad I did. 13" pedestal is the correct height for me to be in a comfortable sitting position, I'm 6'1".
PostPosted: 19 Jun 2011, 09:23
Makes sense now! Thanks for the explanation. :D
This Site is Rated PG, No Politics, No Porn, No Bashing allowed!
Tact is the knack of making a point without making an enemy - Isaac Newton
PostPosted: 19 Jun 2011, 09:29
on my 12ft meyers with 10HP johnson the bench seat i mounted the swivel seat to is only about 14 inches from the transom, I had to offset about 6 inches right so the tiller wouldnt be obstructed by the seat. I'm 6'3" also and i wish i would have moved about another 3" to the right, after about 20min the angle is just a bit uncomforatable.
PostPosted: 19 Jun 2011, 16:35
Valid point. My pedestal mount is 30" from the transom. On my Aluma 1442 that puts it directly in the middle of the bench.
HD
PostPosted: 19 Jun 2011, 19:37
Personally, I've never seen anyone use a tiller steer from the center of the seat. I know on any boat I've ever owned it would be very uncomfortable for your arm to do so.
Lowe 1236/Mercury 9.9 2 stroke
Triton 1440MV/Mercury 25hp 2 stroke
PostPosted: 19 Jun 2011, 19:59
I had mine centered for most of the first year, my arm was pretty much behind the seat at a weird angle. Now with the seat about 5 inches to the right, I can sit with my seat toward the port side with my feet still in front of the bench and rest my arm on the tiller comfortably all day. I can also see around a passenger now because that seat is centered.
PostPosted: 19 Jun 2011, 20:28
I offset my seat, it is more comfortable and I have better control. With the seat in the center if I made a left turn my arm would be back behind the seat making it uncomfortable.
15ft Klamath Advantage, 25hp Honda Tiller, Minn Kota 55 Ipilot, Cannon Downriggers, Nice custom bimini top and more fishing gear than I really need.
Locksmith in Fremont
PostPosted: 19 Jun 2011, 20:59
After building my last boat. I would say YES centered and offset. I would buy two of the pin type bases and center the one. The other would be offset to run the tiller. If I HAD to choose one I would choose centered. I built mine offset and for the short times while running the tiller it was great. But for the majority of the time while fishing the offset rear seat caused a bit of a lean to that side a bit when I had a partner along. It would have been much more comfortable if it were centered.
PostPosted: 19 Jun 2011, 22:12
I have mine rigged with a sliding track lets you move back and forth; don't think it will be comfortable with fixed center pedastal if you run motor for long runs jmho; good luck! 8)
PostPosted: 19 Jun 2011, 22:47
I do and it works fine for me but not for all. I just purchased a extension with a elbow to see if it is better but for me I just centered the seat beacause I am a big guy and when driving I turn my seat so the back is opposite the handle and sit sideways. I have a 7 inch riser but if you weigh 125 pounds it probably will not matter where you mount it but I am 6 2 268 lbs. and to be off center would be suicide.
PostPosted: 20 Jun 2011, 08:18
This where clamp on seats really help. I adjusted my drivers seat a couple times until
I found the sweet spot.
'77 Crestliner Voyager Dlx 16' (semi V), 'Spartan WondeRoll Tilt Trailer, 88 Johnson 30 hp, '87 Evinrude 30 hp, '81 Johnson 25 hp
PostPosted: 20 Jun 2011, 10:02
Mine's offset.
“There’s a fine line between fishing and just standing on the shore like an idiot.” ~Stephen Wright
The Livin Large Project - viewtopic.php?f=21&t=14160
PostPosted: 21 Jun 2011, 21:35
Gonna center it with a 13" fixed post..I can run it from the seat or from the front of the bench area sitting on a flotation cushion. I extended the platform about 1' in front of the rear bench should work good. Thanks everyone! =D>
PostPosted: 21 Jun 2011, 23:07
jay d even if you have already decided on the way you are going to go i just wanted to throw in my 2 cents. As i am 6'2'' and have just started using my first john, the rear seat post centered in the boat for operating the tiller is not 100 percent as functional as may be possible. I wish my seat was off set so i could operate the tiller with my left hand and just off set the weight with trolling motor and gear storage.
Users browsing this forum: BoatDawg4120, Google Adsense [Bot], kofkorn, onthewater102, raymerica and 52 guests
bluewaterled
