It is currently 23 Sep 2014, 18:21
Wired2fish
 Page 1 of 1 [ 14 posts ]
 Post subject: Homemade Outriggers?
PostPosted: 26 Jul 2013, 21:39
Anyone built a set of outriggers at home? I want to be able to run a wide spread while drift fishing for cats, walleye, and wipers. I had originally thought about a 10' stick of 3/4" conduit sleved 2' into a 10' 1" stick of conduit giving me a total of 18' off each side of my boat. My other option would be a set of extendable painters poles. Anyone built anything like this? They will not be used for trolling, only drift fishing.
PostPosted: 28 Jul 2013, 13:04
Conduit is seriously heavy, if one side was extended without the other side extended
the weight offset would tip the boat over. Try holding a 18' piece of conduit by one end
and you will get the idea. How big is your boat?
I would recommend aluminum, either the painters poles or a telescoping pool/floor squeegee.
They could be mounted in the oar locks and locked down when extended as well....Jerry :)
20' Lowe Olympic Jon Boat AlumaZilla
viewtopic.php?f=21&t=20643
HB 1197C
PostPosted: 28 Jul 2013, 13:52
Look into the extendable paint poles. I am not sure how long they get, but I have seen them used for that purpose.
Sam
PostPosted: 29 Jul 2013, 23:10
I disagree about the weight of conduit. If one uses EMT thinwall, in the size(s) he's suggesting, there really isn't that much weight to it. I might suggest you wrap that 3/4" EMT with a pool noodle. Not excessive weight, and the noodle will give you a reasonable amount of flotation to your outriggers.
Roger
PostPosted: 30 Jul 2013, 14:03
I built a set out of 4" pvc as the actual outrigger and connected to 1 1/2 and 1 sleeves of pvc and using a reducer on one side then drilled holes into the pcs so it was adjustable. I used this system on a canoe for a few years.
PostPosted: 30 Jul 2013, 14:56
Rod Riggers!
Whack e'm and stack 'em
Fillet and release into hot grease
PostPosted: 30 Jul 2013, 16:56
I want to see a picture of this.
PostPosted: 31 Jul 2013, 14:37
Maybe I have it wrong but this is what I thought outriggers where. Ive heard of down riggers as well, am I mistaken?
PostPosted: 03 Aug 2013, 01:23
Ridgid conduit is heavy, however, EMT is not. The boat is a 1652 john. I can bass fish 2 guys off one side with very little list to the boat. I understand the weight would be further out acting more efficiently as a lever, but overall weight would be less than >10lb per side.
Roger
Wrong kind of outriggers fellas. What I am talking about holds lines out away from the boat, not something to add any stability.
Captain Ahab wrote:
Rod Riggers!
I do like the rod riggers, but there are 2 problems. 1) I have nowhere to mount the rocket launcher style holders that rod riggers need. 2) I have 7' rods that I can position almost anywhere anyway I want, as I already have 6 of these style rod holders mounted (2 on the bow deck, 2 midship, and 2 on transom gusset).
What I am looking for would be something that mounts in the oarlocks with a simple release at the ends so my midship lines can be run wide, covering the most "ground" possible.
I am leaving mid next week for a vacation of wiper and river cat fishing, but I will put something together when I get back and get a picture or two thrown up.
PostPosted: 03 Aug 2013, 07:09
WHOOPS! Color most of us em-bare-assed. Looks like Capt. Ahab is the only one with the correct thought process.
Sorry for the confusion.
Roger
PostPosted: 03 Aug 2013, 07:16
Roger
No worries, I should have been a little more specific. Obviously scaled down, but here is what I am looking for:
I do like the PVC outriggers though. I remember canoeing the boundry waters in Canada in high school with the Boy Scouts, we were in the middle of a huge lake when a heck of a storm blew up. We ended up tying canoes together to act as each others outriggers to add some stability until we could get into calmer water. Those would have been pretty handy
PostPosted: 03 Aug 2013, 11:41
Some 15ft outriggers can be had for $128 here, probably not worth the trouble of making your own.
http://www.westmarine.com/webapp/wcs/st ... f0jQKymSCg
Whats a wiper?
Tim
16ft 1989 Fisher SV-2 w 1988 48hp SPL Johnson "CIGAR BARGE"
(engine looks like a wreck but runs great)
Used to have 1972 14ft Lund w 1977 15hp Mariner
(engine looked great but always ran marginal)
XLINE SPORTSMANS CLUB
PostPosted: 03 Aug 2013, 15:02
Whats a wiper?
Tim
Thanks for the link, I will check it out.
A wiper is a sterile hybrid of a white and striped bass. They are very agressive and a TON of fun to catch. In the mid to late summer they will herd gizzard shad into a tight ball and run them to the surface similar to the way tuna feed. We watch for the shad breaking the surface or gulls circling one specific place and run over to the frenzy. Dump anything that looks like a shad into the mess and hold on.
PostPosted: 04 Aug 2013, 16:15
Here are some used ones
http://chicago.craigslist.org/wcl/boa/3954469230.html
Tim
Users browsing this forum: Google [Bot], hfd100, minuteman62-64, patman8582, Yahoo [Bot] and 68 guests
bluewaterled
