It is currently 21 Sep 2014, 08:05
mud-skipper
 Page 1 of 3 [ 31 posts ]  Go to page 1, 2, 3  Next
PostPosted: 15 Jun 2009, 22:41
I have been looking for some good rod holders to mount on my boat, but I didnt really like any of the ones that I saw for sale in the stores. So I got some 4" PVC pipe and made some of my own. Once you get the hole pattern figured out, you can make batches of these pretty quick.
I got the idea from http://www.catfish1.com/forums/showthread.php?t=1702, but I made a few small changes...namely, I used a 1 3/4" bit for the bottom hole, but I used a 1 1/4" bit for the top hole to keep the rod a little more securely in place. I also rounded the edges out a little more on the bench sander.
PostPosted: 15 Jun 2009, 23:17
That's pretty cool. I'd consider ganging a couple together about 8" apart for my catfishing trips.
Jamie
My Seadoo Powered Bass Boat http://www.tinboats.net/forum/viewtopic.php?f=21&t=8385
YouTube channel http://www.youtube.com/user/ranchero50
PostPosted: 16 Jun 2009, 00:44
I have a bunch of those in storage.I made mine up to use a carriage bolt and nut to mount them in my oar locks and adjust the angle of the rod.I also had a mount so I could mount the rod holders to it and then clamp it across the gunnels.That was adjustable also,so I could fit different width boats.Everything is packed up in storage or I would post a bunch of pics.
http://www.discoversouthcarolina.com
Decking Do's and Don'ts Link.
Bow Stop Set Up Link.
Goal Post Style Trailer Guides Link.
How to post pics link.
PostPosted: 16 Jun 2009, 02:16
Are you not afraid the rod will pull free?
Whack e'm and stack 'em
Fillet and release into hot grease
PostPosted: 16 Jun 2009, 08:59
thanks for the tip
1989 basstracker tx17
PostPosted: 16 Jun 2009, 09:07
I had that concern at first with my set ups.As long as kept my rods at a 30* angle or more everything was fine.Biggest fish i caught on that was a 12lbs catfishy.With YoungclayB's set up,I would be concerned that a big fish could pull the holders mounting screw out of the hull.If he's chasing small game, like panfish,he should have no issues.A catfish or other large fish could do some damage.
PostPosted: 16 Jun 2009, 09:14
I need to get a picture of my buddy Rat's holder. He did the same thing but he has a bracket that mounts the top rail with 4 or 5 holders on it. It clamps done so it is adjustable to either side, front, back, another boat.... I will get a picture of it later. I think it is on my home computer
PostPosted: 16 Jun 2009, 09:20
i'd like to see that, i've been brainstorming for awhile on something like that. mobile so could go up front for crappie, sides for cats and rear for whites, and be able to stow it if i don't need it that day. lots of ideas but nothing i'm completely satisfied with. looking forward to those pics!
We have only this moment; Shining like a star in our hand, and melting like a snowflake.
My Boat: viewtopic.php?f=21&t=7047
My Photo Page:http://www.flickr.com/photos/swilliams74/
PostPosted: 16 Jun 2009, 09:43
WoW nice job!!! I wish this post was posted about 2 years earlier, back then I was looking for the store bought ones myself, and your right.... the retail ones are crap-ola!!
Two stroke isn't enough, four strokes is way too many!! Image
PostPosted: 16 Jun 2009, 10:03
I think I'll probably put another screw in each holder to keep the holder from "rocking" on the gunnel when a fish is on...a second screw about an inch below the gunnel screw should do the trick.
PostPosted: 29 Jun 2009, 11:32
thats an awsome idea i have been brainstorming trying to com up with something for my boat what size pvc did you use?
PostPosted: 21 Feb 2012, 15:12
Here's a simple little rod holder for storing rods while underway made from thin-walled 1 1/4" PVC pipe, t-joints and elbows. Best of all you can make it for as many, or few rods as you like. None of the components are glued together, so I can take it apart and add to it at any time. I also drilled one small hole in the rear elbows to allow for water drainage. It is screwed into the aluminum rubrail using #8 stainless steel screws dipped in 3M 5200 marine caulk. The tiller extension works great too, and is also made from the same 1 1/4" thin walled PVC with a couple of pipe clamps. I also made a PVC bilge pump using a thin piece of bamboo, a couple flaps of rubber and a round plastic "piston" cut out of an old dust pan. It's fully collapsible and pumps tons of water.
EDIT: I think I got the pics figured out....I think.
PostPosted: 21 Feb 2012, 15:33
Pictures?
PostPosted: 21 Feb 2012, 22:27
pvc get brittle with age so keep a eye on that down the road
g3 pf 175 converted to multi species assault boat.
http://www.tinboats.net/forum/viewtopic.php?f=21&t=23510&p=241047#p241047
monark 1436 flat bottom w/johnson 9.9 hp. eagle cuda 350 w/gps.minn-kota endura c2 30lb.
PostPosted: 21 Feb 2012, 22:59
Pretty cool.
I like a rod holder that is sturdy, secures the rod, and is easy to get the rod out of when a biggun has it bowed over.
Jonah "Bug"
www.RiverBottomOutdoors.com
Facebook
https://www.facebook.com/RiverBottomOutdoors
My Boats:
1656 CCJ http://www.tinboats.net/forum/viewtopic.php?f=21&t=29361
1448 MV http://www.tinboats.net/forum/viewtopic.php?f=21&t=15412
Users browsing this forum: DMGO, erictetterton, toecutter and 31 guests
