Jet john
SC Designs
Jet john
Post by SC Designs » 08 Feb 2017, 10:59
Yo Paintman, check out my latest build I just posted. I seal everything with 3M 5200 and stainless screws then come back over it with fiberglass and bondo for smoothing.
CedarRiverScooter
Jet john
Post by CedarRiverScooter » 08 Feb 2017, 22:46
I also used fiberglass filler for smoothing. I recommend epoxy resin for the fiberglass filler. Polyester can absorb water & has less adhesion to boot.
stinkfoot
Jet john
Post by stinkfoot » 08 Feb 2017, 23:17
What happens when you nail a rock with the Bondo?
SC Designs
Jet john
Post by SC Designs » 09 Feb 2017, 09:13
The bondo is very small amounts, basically when the glass is laid it still creates and uneven surface so after sanding you still have high and low spots, that's where the bondo comes in. Its not large amounts to fill up huge holes. It's a given if a person smacks a huge rock, no matter whats under there on the hull, it stands the possibility of doing damage. I personally try to stay away from the rocks...lol.
Paintman
Jet john
Post by Paintman » 12 Feb 2017, 01:50
Little work done
Paintman
Jet john
Post by Paintman » 12 Feb 2017, 18:05
More progress
Paintman
Jet john
Post by Paintman » 12 Feb 2017, 18:34
Some more pics
SC Designs
Jet john
Post by SC Designs » 13 Feb 2017, 09:09
Looking Good !!! =D>
CedarRiverScooter
Jet john
Post by CedarRiverScooter » 13 Feb 2017, 14:02
Great job!
Transition panel should work good to avoid cavitation.
Paintman
Jet john
Post by Paintman » 21 Feb 2017, 02:11
Jet fitted
Paintman
Jet john
Post by Paintman » 22 Feb 2017, 20:57
Little work
flex
Re: Jet john
Post by flex » 22 Feb 2017, 23:36
Hey buddy! Haha. I also joined to post my build!
Sent from my HTC One M9 using Tapatalk
Paintman
Jet john
Post by Paintman » 22 Feb 2017, 23:39
Awesome,what r u building
handyandy
Jet john
Post by handyandy » 23 Feb 2017, 10:42
So are the pump housings on those jet skis composite with a metal wear sleeve in them?
Paintman
Jet john
Post by Paintman » 23 Feb 2017, 20:58
No all composite,the jet is aluminum
