Jet john
Paintman
Jet john
Post by Paintman » 23 Feb 2017, 21:01
Ready for primer
CedarRiverScooter
Jet john
Post by CedarRiverScooter » 24 Feb 2017, 21:26
Paintman - looking great! What type of paoint are you going to use?
Handy Andy - The PWC makers all had their own designs.. My Polaris has an aluminum wear housing. My friend's Sea Doo had a plastic wear ring insert. Some makers used stainless steel, or at least it was an aftermarket part.
Sucking up sand & gravel definitely chews them up!
Paintman
Jet john
Post by Paintman » 24 Feb 2017, 21:44
Gonna use this on the bottom
Paintman
Jet john
Post by Paintman » 25 Feb 2017, 22:08
Looks like factory
SC Designs
Jet john
Post by SC Designs » 27 Feb 2017, 09:01
Looks great, you are definitely heading in the right direction !!!!
Paintman
Jet john
Post by Paintman » 09 Mar 2017, 11:26
Wetlanders slick bottom
stinkfoot
Jet john
Post by stinkfoot » 09 Mar 2017, 20:07
Be interested how that holds up versus my Goop Coat-it. What kind of rivers are you on Paintman? I am usually on small round granite in the rivers round here..
Paintman
Jet john
Post by Paintman » 09 Mar 2017, 21:04
Mostly submerged logs that like to break lower units
stinkfoot
Jet john
Post by stinkfoot » 09 Mar 2017, 23:41
Paintman wrote:Mostly submerged logs that like to break lower units
Should slip over them nice and easy then. Mine is already getting scratched up.
Paintman
Jet john
Post by Paintman » 09 Mar 2017, 23:43
Check out wetlanders www.bottomcoatings.com
Tman
Jet john
Post by Tman » 10 Mar 2017, 09:53
Paintman wrote:Wetlanders slick bottom
did you use the primer also or just a topcoat kit?
1970's Ouachita Semi V Conversion - http://forum.tinboats.net/viewtopic.php?f=21&t=42520
Paintman
Jet john
Post by Paintman » 10 Mar 2017, 11:06
Primer as well
Paintman
Jet john
Post by Paintman » 14 Mar 2017, 21:22
Ready to flip back over
Paintman
Jet john
Post by Paintman » 14 Mar 2017, 22:23
One more pic
CedarRiverScooter
Jet john
Post by CedarRiverScooter » 15 Mar 2017, 09:18
Really smooth spoon!
Where does the exhaust exit? In tunnel?
Also, will you have a ride plate?
