Motors
1984 johnson 6 hp question
<blockquote data-quote="hamar507" data-source="post: 115410" data-attributes="member: 1953"><p>I have a 1984 Johnson 6hp and just replaced the impeller and water pump. I am having a serious problem getting the lower unit back on. Everything seems to line up shaft, water tube but it will not come back together. How much force is necessary. I can get it to within an inch or so but as I tighten the 3 bolts the prop will not turn. Thanks</p></blockquote><p></p>
[QUOTE="hamar507, post: 115410, member: 1953"] I have a 1984 Johnson 6hp and just replaced the impeller and water pump. I am having a serious problem getting the lower unit back on. Everything seems to line up shaft, water tube but it will not come back together. How much force is necessary. I can get it to within an inch or so but as I tighten the 3 bolts the prop will not turn. Thanks [/QUOTE]
Motors
