Motors
1990 mariner 8hp not pumping water thermostat?
<blockquote data-quote="jy951" data-source="post: 407067" data-attributes="member: 16602"><p>I pulled the lower unit off and the impeller looked good. The rubber boot that connected the water pump housing to the water tube was out of place slight and torn. I ran a clothes hanger up the water tube to try and loosen the obstruction with no success. I opened the thermostat housing and noticed there was no thermostat. I then discovered the blockage was right at the exit nipple of the thermostat housing. I just need that rubber piece that connects the water pump housing to the tube and I should be good. I appreciate all the input. Thanks.</p></blockquote><p></p>
[QUOTE="jy951, post: 407067, member: 16602"] I pulled the lower unit off and the impeller looked good. The rubber boot that connected the water pump housing to the water tube was out of place slight and torn. I ran a clothes hanger up the water tube to try and loosen the obstruction with no success. I opened the thermostat housing and noticed there was no thermostat. I then discovered the blockage was right at the exit nipple of the thermostat housing. I just need that rubber piece that connects the water pump housing to the tube and I should be good. I appreciate all the input. Thanks. [/QUOTE]
Motors
