Motors
2002 25hp Mercury lower unit
<blockquote data-quote="ktoelke54" data-source="post: 464342" data-attributes="member: 21618"><p>The key to the bicycle pump pressure tester was the valve stem from an bicycle inner tube and the plastic tube that came with the lower unit fill pump. Remove the valve stem ( by this I mean the rubber part that sticks out an inch and a half or so) from the bicycle tube, install it in the fill pump tube (couple small hose clamps) and you have a pressure tester. </p><p></p><p></p><p>Sent from my iPhone using Tapatalk</p></blockquote><p></p>
[QUOTE="ktoelke54, post: 464342, member: 21618"] The key to the bicycle pump pressure tester was the valve stem from an bicycle inner tube and the plastic tube that came with the lower unit fill pump. Remove the valve stem ( by this I mean the rubber part that sticks out an inch and a half or so) from the bicycle tube, install it in the fill pump tube (couple small hose clamps) and you have a pressure tester. Sent from my iPhone using Tapatalk [/QUOTE]
Motors
