Boat House
2nd bilge pump
<blockquote data-quote="BigTerp" data-source="post: 380158" data-attributes="member: 9169"><p>Thanks again.</p><p></p><p>Going to go with an 1100gph installed on the other side of my bilge and instead of using the "standard" bilge hose will be picking up some Shields 148 series smooth bore VAC extra heavy duty hose. Going to get some 3/4" hose as well to replace the "standard" bilge hose on my other bilge pump. Should have done all of this last summer after punching a hole in my hull and realizing my 750gph pump wasn't quite enough. Better late then never I guess.</p></blockquote><p></p>
[QUOTE="BigTerp, post: 380158, member: 9169"] Thanks again. Going to go with an 1100gph installed on the other side of my bilge and instead of using the "standard" bilge hose will be picking up some Shields 148 series smooth bore VAC extra heavy duty hose. Going to get some 3/4" hose as well to replace the "standard" bilge hose on my other bilge pump. Should have done all of this last summer after punching a hole in my hull and realizing my 750gph pump wasn't quite enough. Better late then never I guess. [/QUOTE]
Boat House
2nd bilge pump
