Motors
71' Evinrude 18 HP won't start
<blockquote data-quote="webrx" data-source="post: 285511" data-attributes="member: 10010"><p>Have you done anything recently to the motor? If so, check that first.</p><p></p><p>If not, it is possible that you have a fuel, or spark issue. If fuel checks out, then check spark. I have just gone through a friends 73 and ended up having a bad coil, worked fine for a while then when it got hot it quit. Lots of little things on these motors can cause what you are experiencing so you just gotta start with the basic, compression, fuel spark. Points can slip, condenser wires can break, coils can go bad, carbs can get a slug of dirt in them, etc.</p><p></p><p>Dave</p></blockquote><p></p>
[QUOTE="webrx, post: 285511, member: 10010"] Have you done anything recently to the motor? If so, check that first. If not, it is possible that you have a fuel, or spark issue. If fuel checks out, then check spark. I have just gone through a friends 73 and ended up having a bad coil, worked fine for a while then when it got hot it quit. Lots of little things on these motors can cause what you are experiencing so you just gotta start with the basic, compression, fuel spark. Points can slip, condenser wires can break, coils can go bad, carbs can get a slug of dirt in them, etc. Dave [/QUOTE]
Motors
