Motors
9.5 johnson wont start
<blockquote data-quote="RBuffordTJ" data-source="post: 200653" data-attributes="member: 1385"><p>Yeah those are pretty simple, the smaller outboards don't usually have any gear shimming to do so no specialty tools needed. Seal up that gear case good and have it pressure tested to make sure the seals are in good.</p><p></p><p>If your fuel fuel pump is leaking the diaphragm inside probably busted, so no gas movement. Rubber rots at the same speed and ethanol speeds that up dramatically, make sure to use an ethanol stabilizer in the fuel and if you can get the blue fuel lines and primer balls they sell now that are ethanol resistant to help keep everything fresh and flexible.</p><p></p><p>Good luck with it man.</p><p>Bufford</p></blockquote><p></p>
[QUOTE="RBuffordTJ, post: 200653, member: 1385"] Yeah those are pretty simple, the smaller outboards don't usually have any gear shimming to do so no specialty tools needed. Seal up that gear case good and have it pressure tested to make sure the seals are in good. If your fuel fuel pump is leaking the diaphragm inside probably busted, so no gas movement. Rubber rots at the same speed and ethanol speeds that up dramatically, make sure to use an ethanol stabilizer in the fuel and if you can get the blue fuel lines and primer balls they sell now that are ethanol resistant to help keep everything fresh and flexible. Good luck with it man. Bufford [/QUOTE]
Motors
