Motors
95 Johnson 40hp tiller
<blockquote data-quote="Pappy" data-source="post: 161965" data-attributes="member: 3278"><p>We don't know that the engine is overheating yet. Do yourself a favor and start with a compression check and let's go from there. For checking temps you can disconnect the tan lead from the cyl. head and try running again or an alternate method would be to check with a digital temp gun at the time the issue appears. Check at the top of the cylinder head. That engine should be warmer at idle than at WOT.</p></blockquote><p></p>
[QUOTE="Pappy, post: 161965, member: 3278"] We don't know that the engine is overheating yet. Do yourself a favor and start with a compression check and let's go from there. For checking temps you can disconnect the tan lead from the cyl. head and try running again or an alternate method would be to check with a digital temp gun at the time the issue appears. Check at the top of the cylinder head. That engine should be warmer at idle than at WOT. [/QUOTE]
Motors
