Boat House
Bow mount trolling motor bouncing around
<blockquote data-quote="eshaw" data-source="post: 463172" data-attributes="member: 22134"><p>I had that problem. What I did was buy one of the super cheap transom savers from Walmart that has a rubber V on one end. I took that off, made a base mount for it and mounted it under the shaft. Then I used a piece of velcro to secure the shaft to the rubber piece. Works like a charm.</p></blockquote><p></p>
[QUOTE="eshaw, post: 463172, member: 22134"] I had that problem. What I did was buy one of the super cheap transom savers from Walmart that has a rubber V on one end. I took that off, made a base mount for it and mounted it under the shaft. Then I used a piece of velcro to secure the shaft to the rubber piece. Works like a charm. [/QUOTE]
Boat House
