Boat House
Couple project questions
<blockquote data-quote="richg99" data-source="post: 409493" data-attributes="member: 4376"><p>I just put the Blue foam under my deck on my new hull. </p><p></p><p>With the exact same concerns that you had, and the fact that my strakes are partially filled with thick trolling motor wires etc., I cut each foam "board" about 3/4 of an inch short (narrower). My thought is that the foam filler "boards" will still do most of their job, all of the while letting any water flow around them more easily.</p><p></p><p>I wanted the water to flow out of the hull as fast as possible so that it wouldn't be sitting and soaking the foam for days at a time.</p><p></p><p>richg99</p></blockquote><p></p>
[QUOTE="richg99, post: 409493, member: 4376"] I just put the Blue foam under my deck on my new hull. With the exact same concerns that you had, and the fact that my strakes are partially filled with thick trolling motor wires etc., I cut each foam "board" about 3/4 of an inch short (narrower). My thought is that the foam filler "boards" will still do most of their job, all of the while letting any water flow around them more easily. I wanted the water to flow out of the hull as fast as possible so that it wouldn't be sitting and soaking the foam for days at a time. richg99 [/QUOTE]
Boat House
