Boat House
Floor ideas
<blockquote data-quote="CedarRiverScooter" data-source="post: 462741" data-attributes="member: 15465"><p>No Need for marine plywood. Exterior grade uses same glue. Marine just has less voids. Many here use the 'Old Timer's formula' which is mainly spar varnish to seal up the ply. I recommend putting the covering on 1st (vinyl or carpet) then screwing it down to the ribs, leaving the screw heads exposed. They will countersink-in some just with torque. This way you can remove floor with out having to recover it.</p></blockquote><p></p>
[QUOTE="CedarRiverScooter, post: 462741, member: 15465"] No Need for marine plywood. Exterior grade uses same glue. Marine just has less voids. Many here use the 'Old Timer's formula' which is mainly spar varnish to seal up the ply. I recommend putting the covering on 1st (vinyl or carpet) then screwing it down to the ribs, leaving the screw heads exposed. They will countersink-in some just with torque. This way you can remove floor with out having to recover it. [/QUOTE]
Boat House
Floor ideas
