Motors
Free 1975 Johnson 6 hp
<blockquote data-quote="Pappy" data-source="post: 180900" data-attributes="member: 3278"><p>If AJ has a parts motor for you I would definitely keep it. They are great runners when properly tuned. If his parts motor is a short shaft and has a good lower unit then all you have to do is pull the powerhead and swap to the other midsection. Requires a single gasket and about an hour of your time.</p></blockquote><p></p>
[QUOTE="Pappy, post: 180900, member: 3278"] If AJ has a parts motor for you I would definitely keep it. They are great runners when properly tuned. If his parts motor is a short shaft and has a good lower unit then all you have to do is pull the powerhead and swap to the other midsection. Requires a single gasket and about an hour of your time. [/QUOTE]
Motors
