Boat House
Glass on a Jon ?
<blockquote data-quote="bassboy1" data-source="post: 161908" data-attributes="member: 55"><p>Fiberglass is not a good repair medium for aluminum boats. The expansion rates, as well as flexing differences will cause them to separate relatively quickly. </p><p></p><p>How big is the hole? Small enough for a rivet to fill? If not, then riveting on a patch is probably the best method to do at home. If it is a split at a corner or seam, it will need a little more attention, but still doable.</p></blockquote><p></p>
[QUOTE="bassboy1, post: 161908, member: 55"] Fiberglass is not a good repair medium for aluminum boats. The expansion rates, as well as flexing differences will cause them to separate relatively quickly. How big is the hole? Small enough for a rivet to fill? If not, then riveting on a patch is probably the best method to do at home. If it is a split at a corner or seam, it will need a little more attention, but still doable. [/QUOTE]
Boat House
Glass on a Jon ?
