Boat House
Homemade Transducer Mount
<blockquote data-quote="thudpucker" data-source="post: 290054" data-attributes="member: 1422"><p>hanks for the tip.</p><p>I had that problem on a boat. It turned out to be some rough surface on the bottom just a few feet in front of the Transducer.</p><p>After I sanded that down a bit, it worked fine. The first photo is the re-mount inside the boat. I put a piece of Aluminm down to keep my big feet from wrecking the Xducer cable.</p><p>If yourT transducer is flipping up, re-mount it thru-hull if you can. I did that with my 1648. Second photo is the Slow speed fishing transducer mount.</p><p>[ATTACH=full]44897[/ATTACH] [ATTACH=full]44898[/ATTACH]</p></blockquote><p></p>
[QUOTE="thudpucker, post: 290054, member: 1422"] hanks for the tip. I had that problem on a boat. It turned out to be some rough surface on the bottom just a few feet in front of the Transducer. After I sanded that down a bit, it worked fine. The first photo is the re-mount inside the boat. I put a piece of Aluminm down to keep my big feet from wrecking the Xducer cable. If yourT transducer is flipping up, re-mount it thru-hull if you can. I did that with my 1648. Second photo is the Slow speed fishing transducer mount. [ATTACH type="full" alt="Old thru hull 2.jpg"]44897._xfImport[/ATTACH] [ATTACH type="full" alt="Transducer hanger.jpg"]44898._xfImport[/ATTACH] [/QUOTE]
Boat House
