Motors
How does a power trim stop?
<blockquote data-quote="Pappy" data-source="post: 405214" data-attributes="member: 3278"><p>The pump will keep pumping until pressure builds and opens a pressure relief valve.....if it can build enough static pressure. Usually that valve only opens when hitting a submerged object. </p><p>Since the motor keeps running as long as it has power there is a thermal cut-out switch built into most motors that will stop the motor until the switch cools and the process starts again.</p></blockquote><p></p>
[QUOTE="Pappy, post: 405214, member: 3278"] The pump will keep pumping until pressure builds and opens a pressure relief valve.....if it can build enough static pressure. Usually that valve only opens when hitting a submerged object. Since the motor keeps running as long as it has power there is a thermal cut-out switch built into most motors that will stop the motor until the switch cools and the process starts again. [/QUOTE]
Motors
