Motors
Installing lower unit
<blockquote data-quote="Callmecaptain" data-source="post: 382902" data-attributes="member: 17992"><p>I got the lower unit installed last night. I actually had the throttle and shift cables disconnected because I was removing my jet outboard pump and installing my prop lower unit. I put the remote throttle into drive (first indent) while I had the lower unit in forward with the shift rod turned to the left, right before it shifts into neutral.</p><p></p><p>Everything checked out the first time, hitting the gears at the right spots, Forward, Neutral, and Reverse.</p><p></p><p>The previous owner thought it was a good idea to lift the shift rod, cost me $400 to fix. :evil: </p><p></p><p>Oh well, it should be ready to run this weekend.</p><p></p><p> :beer:</p></blockquote><p></p>
[QUOTE="Callmecaptain, post: 382902, member: 17992"] I got the lower unit installed last night. I actually had the throttle and shift cables disconnected because I was removing my jet outboard pump and installing my prop lower unit. I put the remote throttle into drive (first indent) while I had the lower unit in forward with the shift rod turned to the left, right before it shifts into neutral. Everything checked out the first time, hitting the gears at the right spots, Forward, Neutral, and Reverse. The previous owner thought it was a good idea to lift the shift rod, cost me $400 to fix. :evil: Oh well, it should be ready to run this weekend. :beer: [/QUOTE]
Motors
