Boat House
need more room
<blockquote data-quote="Arkdave" data-source="post: 112794" data-attributes="member: 1982"><p>" Fisherman" hasnt said, But im assuming his Boat is 32 wide like mine, Don't you think Given the Short Length of the Boats(10 foot) That a Frame work Built Like his Drawing (im Thinking square tubing Welded at the corners) Would keep the Structure strong enough? </p><p>If he uses removable seats, I cant see that causing a weight problem! the Flotation loss is A problem Without adding the Floor!!</p></blockquote><p></p>
[QUOTE="Arkdave, post: 112794, member: 1982"] " Fisherman" hasnt said, But im assuming his Boat is 32 wide like mine, Don't you think Given the Short Length of the Boats(10 foot) That a Frame work Built Like his Drawing (im Thinking square tubing Welded at the corners) Would keep the Structure strong enough? If he uses removable seats, I cant see that causing a weight problem! the Flotation loss is A problem Without adding the Floor!! [/QUOTE]
Boat House
need more room
