Motors
Need some help with a water pump issue with 20hp Mercury
<blockquote data-quote="lil miss boo" data-source="post: 331086" data-attributes="member: 11754"><p>Had the same problem with mine. After hours of trying to figure out what i did wrong and blowing air through the outlet hose i finally took the lower unit off and put the metal tube in first and then gently put the lower back on making sure the tube went into the grommet coming out of the water pump. Tightened it all back up and shot a nice stream of water. i checked the schematic for that motor and i couldnt see any bushing for the top of the tube to go into. did this at the beginning of the summer and i havent had a problem with it since.</p></blockquote><p></p>
[QUOTE="lil miss boo, post: 331086, member: 11754"] Had the same problem with mine. After hours of trying to figure out what i did wrong and blowing air through the outlet hose i finally took the lower unit off and put the metal tube in first and then gently put the lower back on making sure the tube went into the grommet coming out of the water pump. Tightened it all back up and shot a nice stream of water. i checked the schematic for that motor and i couldnt see any bushing for the top of the tube to go into. did this at the beginning of the summer and i havent had a problem with it since. [/QUOTE]
Motors
