Boat House
New boat, motor setting???
<blockquote data-quote="surfman" data-source="post: 366986" data-attributes="member: 7404"><p>Raise it to level with the bottom, if it is slightly higher that is okay as long as the prop doesn't vent, if it does then you will need to lower it a bolt hole and try again. The higher the better, less drag, more efficiency.</p></blockquote><p></p>
[QUOTE="surfman, post: 366986, member: 7404"] Raise it to level with the bottom, if it is slightly higher that is okay as long as the prop doesn't vent, if it does then you will need to lower it a bolt hole and try again. The higher the better, less drag, more efficiency. [/QUOTE]
Boat House
