Motors
Oil to gas ratio for idling
<blockquote data-quote="KC_Jones" data-source="post: 468947" data-attributes="member: 23480"><p>A valve setup is exactly what I would do. My plan (if it fits) is to convert to a single 12 gallon tank with an additional 3 gallon tank with the 100:1 mixture. Switch when I run slow, then switch back maybe 30 minutes before I end my day and throttle up. Sounds like the consensus is this shouldn't be a problem.</p><p></p><p>Thanks again for all the responses.</p></blockquote><p></p>
[QUOTE="KC_Jones, post: 468947, member: 23480"] A valve setup is exactly what I would do. My plan (if it fits) is to convert to a single 12 gallon tank with an additional 3 gallon tank with the 100:1 mixture. Switch when I run slow, then switch back maybe 30 minutes before I end my day and throttle up. Sounds like the consensus is this shouldn't be a problem. Thanks again for all the responses. [/QUOTE]
Motors
