Motors
Power Trim & Tilt Leaks Down
<blockquote data-quote="Pappy" data-source="post: 345902" data-attributes="member: 3278"><p>That is a much earlier system than 1988 but Boat2Fast pretty much nailed how to fix it. Man Rel. Valve is always the first place to look.</p><p>Only thing to add to this is that if you know your symptoms "Leaks down" for example, then when reading the manual look at every valve that has to hold pressure while raising the engine. If I am repairing one at the dealership these days we will replace all valves that need to hold pressure under thrust or hold the engine "UP" for times sake. Since you are doing it at home and time is not your enemy you can be more selective.</p></blockquote><p></p>
[QUOTE="Pappy, post: 345902, member: 3278"] That is a much earlier system than 1988 but Boat2Fast pretty much nailed how to fix it. Man Rel. Valve is always the first place to look. Only thing to add to this is that if you know your symptoms "Leaks down" for example, then when reading the manual look at every valve that has to hold pressure while raising the engine. If I am repairing one at the dealership these days we will replace all valves that need to hold pressure under thrust or hold the engine "UP" for times sake. Since you are doing it at home and time is not your enemy you can be more selective. [/QUOTE]
Motors
