Boat House
Protect edge of plywood
<blockquote data-quote="surfman" data-source="post: 424093" data-attributes="member: 7404"><p>Don't forget the holes for attaching, I cut my wood to fit and then went ahead and fastened it all down, then removed it and then painted it. I used epoxy and I taped the screw holes so they would fill with epoxy and would be sure to soak into the edge of the drilled out holes. that varnish mix would probably work just as well. I then had to re-drill the holes of course but I was sure that there was good penetration.</p></blockquote><p></p>
[QUOTE="surfman, post: 424093, member: 7404"] Don't forget the holes for attaching, I cut my wood to fit and then went ahead and fastened it all down, then removed it and then painted it. I used epoxy and I taped the screw holes so they would fill with epoxy and would be sure to soak into the edge of the drilled out holes. that varnish mix would probably work just as well. I then had to re-drill the holes of course but I was sure that there was good penetration. [/QUOTE]
Boat House
