Boat House
Questions about my boat project.
<blockquote data-quote="Thad" data-source="post: 127133" data-attributes="member: 2674"><p>Where would you guys put the battery for the trolling motor? Seems like the easiest place would be in the back, beside the gas tank.</p><p></p><p>Got another question. In what order do you put a deck together so that there are no screw in the carpet? For example, let's say I'm building the bench top for my back bench. I cut out the bench top and then I cut out the square in the middle that will be the lid to the opening. Then I need to make a brace for the bottom side of the bench top so the lid will sit on it. In what order do I put together the bench top, lid, brace, carpet, piano hinge? And then I need to attach the whole thing the the aluminum frame that is already in the boat. How do I do all of this without putting holes in the carpet? I just can't put theses things in order. Everything ends up with having to mess the carpet up.</p></blockquote><p></p>
[QUOTE="Thad, post: 127133, member: 2674"] Where would you guys put the battery for the trolling motor? Seems like the easiest place would be in the back, beside the gas tank. Got another question. In what order do you put a deck together so that there are no screw in the carpet? For example, let's say I'm building the bench top for my back bench. I cut out the bench top and then I cut out the square in the middle that will be the lid to the opening. Then I need to make a brace for the bottom side of the bench top so the lid will sit on it. In what order do I put together the bench top, lid, brace, carpet, piano hinge? And then I need to attach the whole thing the the aluminum frame that is already in the boat. How do I do all of this without putting holes in the carpet? I just can't put theses things in order. Everything ends up with having to mess the carpet up. [/QUOTE]
Boat House
