Boat House
Rear U Bolt Tie Down detail
<blockquote data-quote="Attwanl" data-source="post: 403258" data-attributes="member: 10236"><p>I use one strap across, I wrap around the frame and hook it so its own weight holds the hook tight. Then attach other side, usually one or two clicks and it holds fine. I was racheting it down tight but noticed I was bowing the sides. Guess you wouldn't worry about that if you had transom tie downs. </p><p> The straps have rubbed the paint off the gunnels too.</p></blockquote><p></p>
[QUOTE="Attwanl, post: 403258, member: 10236"] I use one strap across, I wrap around the frame and hook it so its own weight holds the hook tight. Then attach other side, usually one or two clicks and it holds fine. I was racheting it down tight but noticed I was bowing the sides. Guess you wouldn't worry about that if you had transom tie downs. The straps have rubbed the paint off the gunnels too. [/QUOTE]
Boat House
