Boat House
Transome riser question
<blockquote data-quote="hotshotinn" data-source="post: 230519" data-attributes="member: 5440"><p>i was going to bolt it as I donot have a welder for aluminum.welding a riser would be nicer but the cost factor doin it :shock: bolting would be cheaper even useing stainless bolts :mrgreen:</p><p></p><p>i was looking over utube and I found this tracker jet buildup.If you look at the vidio you will see what I want to do.I glad I ran into this as it answers the questions I need to no =D> if you watch the vidio you will see how the motor is mounted and this is what i want to do.I think it is just heavy angle aluminum with the moter bolted onit.</p><p>https://www.youtube.com/watch?v=99u3mm1H2oI</p></blockquote><p></p>
[QUOTE="hotshotinn, post: 230519, member: 5440"] i was going to bolt it as I donot have a welder for aluminum.welding a riser would be nicer but the cost factor doin it :shock: bolting would be cheaper even useing stainless bolts :mrgreen: i was looking over utube and I found this tracker jet buildup.If you look at the vidio you will see what I want to do.I glad I ran into this as it answers the questions I need to no =D> if you watch the vidio you will see how the motor is mounted and this is what i want to do.I think it is just heavy angle aluminum with the moter bolted onit. https://www.youtube.com/watch?v=99u3mm1H2oI [/QUOTE]
Boat House
