New 5 hp motor on auction... $360 right now! Ends at 7pm
wasilvers
Sussex, WI
https://xmilw.neofillbids.com/item.php?id=32839
It's a local auction here in milwaukee (radio station will not shut up about it). Description reads...
The Briggs & Stratton Outboard Motor 5 HP 4 Cycle OHV Engine features: forward-neutral-reverse gear shift, tiller handle control, manual starting, Magnetron electronic ignition, 3-blade aluminum propeller, push button stop with safety lanyard, patented overspeed protection device, neutral start safety switch. Specifications: displacement 11.5 cu. in (189 cc), bore x stroke 2.688" x 2.04", full throttle 4000 RPM, gear ration 1.57/1, recommended transom height 15", weight 56lbs, designed for freshwater use. Certificate must be redeemed by 12/31/09.
Don't know if it will move much or not. It is in the leisure section of the auction, not hunting or sports. Happy bidding.
I edited the title - it's a new motor.
It's not mine, just thought someone here might need one.
