MY AC smells like a wet dog - help -
TinBoats Supporter
Shrewsbury, MA
Turned on the air conditioning in my truck this morning and it smells like a wet dog. Not too overpowering but enough to notice it. Is this something I can fix easily?
No idea what was the cause, but about a month ago I had the same deal with my Taco and thought, oh great... but in a day or two the smell went away.
Edit: fixed typo
mold in the evaporator
take it to your dealer. they make products like frigid fresh you spray in the hvac box and run threw the evaporator, their basically aerasol disinfectants.
I'm almost certain that it will be covered under the factory warranty.
And nice choice of truck I might add =D> (me loves my 03 :mrgreen: and jelous of yer 08)
how many miles? if you send me your vin i can look all that good stuff up for you
i think its a half hour labor charge
LMAO there goes a quick hundred dollars and I betcha they will find 3 other things wrong
on a fancy rig like that? ppppppssssshhhhhhhhhhhh maybe 2 at the most :LOL2:
there is a bulliton to install a evap dry'er kit too if your rigs covered
Jim----
In the meantime Make sure your fresh air intake vents (hood area) are clean and
free of pine straw/leaves etc...Also make sure the AC drain vent
on your firewall is clear of trash...Lots of times your drain
becomes plugged and water will collect and mildew will accumulate
and become contaminated and smelly.....
This smell will be circulated into your AC vents....
You can try this too
https://www.youtube.com/watch?v=bml8dletNbk&feature=player_embedded
Been awhile since I worked on MVAC systems, but...
There is a cabin air filter, maybe it just needs to be replaced
Could have something on the coil - dirt, pollen, dead skin cells - any of these could hold moisture and cause the foul smell
Drain may be slow causing water to set in pan which also causes the smell
I don't know how easy or difficult it is to get to the coil, but it is definitely something you could on your own. There is a product called Bio-Gard and Bio-Fresh that you can spray on the coil after you get it clean to help kill whatever has made into the duct and blower as well.
perchin said:
Jim----
Will do! :beer:
Just got an oil change last week so I will not be going back to the dealer for 3 months or so anyway.
Thanks for the info!
I guess it's always possible you have a wet dog hiding under your hood :roll:
Turning off the a/c and running it just on vent for a while to dry out any residual moisture helps as well. It's not unheard of for mold in the ducting to be causing that smell.
I'm wanting to say that there was a special set of instructions in addition to the owner's manual just for the a/c on my truck that covered things like that. I know the new refrigerant that they use on the newer ones is horrible. I have to run mine on max with the blower on high just to cool the cab down. You used to be able to frost the windows on one by doing that.
Not on all newer ones..... only the Fords I've owned have had that issue.(04 Explorer(exploder) 01 Taurus) All our GM's (03 GMC ext.cab 4x4, 01 Malibu, 98 Monte Carlo Z34) could be refrigerators. :p
I've never owned a Ford until my current F150 that had this problem... ever.
I do own a 1998 Malibu that hasn't had working a/c in over 7 years, though. :roll:
It is not brand specific. (It takes a lot longer to cool off an suv simply because of the increased interior space, unless you have the rear vents as well)
You guys in the north don't know what it's like to have to actually work your a/c to the max anyway. :lol:
