ACarbone624
- Joined
- Dec 6, 2007
- Messages
- 1,393
- Reaction score
- 0
https://www.ford.com/dynamic/metatags/article-detail/223_important_notice_voluntary_recall_update
EDIT: Here is another article....
The Ford Motor Co. has concluded that the recall to prevent a faulty cruise control system from erupting in flames is ineffective in almost 225,000 of the almost 11 million Ford vehicles recalled because of a fire hazard since 1999.
As a result, Ford is issuing a second recall for the almost 225,000 vehicles that were previously recalled for a faulty cruise control system that might fail and cause the vehicle to burn even when parked and turned off.
Ford vehicles covered by the new recall include the gasoline-powered 1992 to 2003 Econoline, 1992 to 1998 Crown Victoria/Grand Marquis, 1993 Bronco, 1995 to 1997 F series pick up, 1993 F series pick up, the 1993 to 1995 Taurus SHO and the 1992 to 1995 Town Car.
The vehicles now recalled for a second time were part of the massive and often confusing Ford recalls since 1999 because of the faulty cruise system which failed and Ford vehicles and consumer homes ablaze.
Ford initially repaired the vehicles by installing a wiring harness around the cruise control switch. The automaker has now concluded the harness does not function properly in roughly 225,000 vehicles. The wiring harness installed on the eight models built between 1992 and 2003 is not compatible with the vehicle electrical system.
The harnesses Ford thought would alleviate the fire danger apparently contain an improperly placed fuse which does not offer sufficient protection if there is an electrical short circuit.
Ford plans to delay notification for vehicle owners until formally reporting the recall failure to the National Highway Traffic Safety Administration (NHTSA) as well as providing Ford dealers with accurate service repair information.
In the meantime, Ford has continued to advise owners to have a dealer disconnect the cruise control system.
