Wallijig
I have buddy that has private pond. He would like to install boat ramp in it for dropping his 14' crestliner flatbottom in easier. The bottom is very soft when walk around edges one sinks ankle to knee deep in mud. also has a cut bank with about 3'-4' drop. however that would not be issue because have a tractor with loader I could cut it out.
Has anyone ever done this? What could I use to firm up shoreline?
I was thinking of doing a treated plywood base with concrete pavers siliconed down to it.
Or with having access to loader tractor wonder if went to rock pile, dumped rocks in and then trying to build off that. But wonder how much maintenance that would need after winter freezing.
Also maybe thinking a system with long treated boards extended from shore back into water with rollers attached and wench on top end to crank boat in and out of water.
