Minn Kota Maxxum Steering Cable Replacement
onthewater102
CT
Trying to figure out which cable to order - they are listed as #127 - Cable Assembly-Right 5' and #128 Cable Assembly-Left 5'. However, despite being listed as the same length the one I broke is longer than the one that is intact - and I cannot tell from this diagram which is which. If I had to guess I'd say I need #127, but that's only because the left cable in the image appears to enter the foot control lined up with the longer track through the pulley.
I was hoping to avoid 35minutes of hold time with Minn Kota customer support if possible.
Thanks to all,
Well, I went and ordered both, and for anyone making the same repair with the same question, the left cable is the longer of the two cables.
