UPDATE! Maybe tin no more
Talk about anything that floats your boat (no pun intended). This is general talk about anything not related to boating/fishing.
the hammer
Post by the hammer »
Considering a move from tin to plastic, Sun Dolphin Pro 120. Need to go to something smaller BUT wider, more stability.
Debating whether to sell "AS IS" or to put some time, effort and cash to square it away. Not like there's a lot to be done, don't get me wrong. I think a lot of guys would be putting a personal stamp anyway.
LDUBS
3
Maybe tin no more
Post by LDUBS »
But wait. What? No more tin boat? Say it ain't so. :? :?
Good luck with the sale and the new boat search.
Have Rod - Will Fish
lovedr79
Maybe tin no more
Post by lovedr79 »
my buddy has one of those. it is ungodly heavy.
1960 yellowboat
1
Maybe tin no more
Post by 1960 yellowboat »
You're actually going to spend $2200 on a plastic boat?
Why not get a paddle boat and put a trolling motor on it?
To each his own, I guess
I just went to the Sun Dolphin website, that thing weighs 238 lbs. Has a 600 lb. capacity, and is 62 inches wide max.
I'd hate to have to muscle that around. Especially with a motor attached.
Oh well, it's your money
Good Luck
the hammer
Maybe tin no more
If there weren't extenuating circumstances, it wouldn't even be a consideration.
gnappi
3
Maybe tin no more
Post by gnappi »
My GF's son had one, it was HEAVY AND it leaked. The manufacturer did nothing but suggest things to stop the leaks. Ultimately he wrote the retailer and they took it back.
Regards,
Gary (in South Florida)
the hammer
Maybe tin no more
1960 yellowboat wrote:
02 Oct 2019, 15:49
Good Luck
I'm not happy about it but there is a very good reason. I have some time to think on it.
LDUBS
3
Maybe tin no more
Post by LDUBS »
Well it is your reasons and not someone else's that really matter.
About the old boat, unless you are pretty certain you will get more back than you put into upgrades, I would sell as is. The new owner can make it their own.
the hammer
Maybe tin no more
LDUBS wrote:
03 Oct 2019, 17:05
I think it's going to be as is, as well. I'm still going to wait until spring to sell it though, prime boat sale season. Who knows, maybe another option will present itself.
I actually placed an order for a Dolphin 7 years ago and cancelled when I came to my senses. The situation was a bit different then.
1960 yellowboat
1
Maybe tin no more
here are two boats you may consider.
A "Pondtoon" custom made 14 ft pontoon type boat made all out of aluminum.
14 ft long and 5 ft wide is the base model.
next is one 14 ft long and 6 ft wide
lastly 16 ft long and 6 ft wide.
www.boatsandfishing.com
Or a Craigcat.
kind of a double catamaran style
www.craigcat.com
good luck
the hammer
Maybe tin no more
05 Oct 2019, 13:58
Or a Craigcat.
www.craigcat.com
good luck
Thanks for the time you've put into trying to find a NON plastic option for a boat for me. That's not sarcasm, absolutely heartfelt. A pontoon style boat isn't an option for either. The "best" option would probably be a Carolina skiff type boat. I need something with a wide hull for stability, in the 14' ballpark.
At least I have about 6 months before prime boat selling season.
ruffhunter
1
Maybe tin no more
Post by ruffhunter »
there are 1242 and 1248 welded jons available that would be my choice. those mini pontoons would be good.
LDUBS
3
Maybe tin no more
Post by LDUBS »
How about a Livingston Boat. It is a glass boat. Guys say it is pretty stable. Looks like they make a 10', 12', 14' and other sizes. I have no idea about cost or availability.
gnappi
3
Maybe tin no more
Post by gnappi »
Hammer, you haven't said what your width requirement is only that you need stability.
The Alweld 1242 is 61" wide and only an inch more or less (depending where you get the specs) with similar capacity than what you're contemplating. If you can go up a bit there are other tin boats from Lowe and alweld in the 14' class that are even wider with better max weight capacities.
Regards,
the hammer
Maybe tin no more
gnappi wrote:
10 Oct 2019, 15:31
It's deck space, not just overall beam width.
