Wired2Fish - Sea Foam Marine PRO and Alpha Angler Rod Giveaway
Fenton, Missouri
Another GREAT giveaway from our friends and TinBoats Sponsor, Wired2Fish!
Sea Foam has introduced a new marine blend that is getting rave reviews across the marine industry. It's called Sea Foam Marine PRO.
Our own, Walker Smith began using it before it was generally available and he tells us his engine has never run better. He has an older model engine, a 1998 model outboard, and he said "my engine runs likes it new and it was noticeable from the first can I ran through it. Better acceleration, better holeshot and idles better too."
Sea Foam has a long history of making all kinds of engines from lawnmowers to big truck engines, run better and more efficient for years and this new Marine PRO product stands to do the same. New or old, it will make your engine run better too!
In this giveaway, Sea Foam has teamed with Alpha Angler to combine a prize package that includes an Alpha Angler ChatterBound rod and a case of the new Sea Foam Marine PRO.
We will have three winners in this giveaway!
https://www.wired2fish.com/giveaways/sea-foam-marine-pro-and-alpha-angler-rod-giveaway/
You can learn more about Sea Foam Marine PRO at https://seafoamsales.com/knowledge-base/how-to-use-marine-pro-fuel-treatment-in-marine-engine-fuel/ or Alpha Angler by clicking here. https://www.alphaangler.com/
Good Luck!!
This giveaway ends January 14th, 2020.
You may enter once per day per email address.
