So I am trying to teach our fairly new cat no to jump on the table or counters. I just learned how to keep it off my car.
[youtube]_CMvfov89Rk[/youtube]
flounderhead59 said:Believe it or not, that is quite close to the best way I know to train a cat to stay off of something. A small squirt gun (used ONLY when the cat is doing the undesired behavior) works wonders. One quick squirt (ONE) and kept out of sight when not in use. Squirt the cat (ONCE) and pretend you didn't even notice the cat or it getting squirted. It will assocciate the act of getting squirted with the bad behavior and not with you and will "learn"
Jim said:flounderhead59 said:Believe it or not, that is quite close to the best way I know to train a cat to stay off of something. A small squirt gun (used ONLY when the cat is doing the undesired behavior) works wonders. One quick squirt (ONE) and kept out of sight when not in use. Squirt the cat (ONCE) and pretend you didn't even notice the cat or it getting squirted. It will assocciate the act of getting squirted with the bad behavior and not with you and will "learn"
Shoot..Thats what the problem is. When it jumps on the counter I come running in with the squirt bottle and it jumps off the counter. I did it all wrong. :x
