My semi v sterling 1408 *COMPLETE MAY 2013*
thatkidhugo
Post by thatkidhugo »
I dont know much about these sterling boats, but I know its a 1408 and I picked it up with everything you see here. A 9.9 merc motor, 2 trolling motors, 2 fish finders and the 3 seats. Its in great shape but I just want to add my own touch to it. I want to extend the deck to the middle seat complete with new carpeting and tuck all the wires ect.
JonBoatfever
Post by JonBoatfever »
nice boat!
Jonboat Jerry
Post by Jonboat Jerry »
Nice find Hugo, Trailer looks brand new too! :)
20' Lowe Olympic Jon Boat AlumaZilla
http://www.tinboats.net/forum/viewtopic ... 21&t=20643
HB 1197C
BearwoodBoats
Post by BearwoodBoats »
Hey
Great Boat Enjoy!
Later
BYOB Fishing
Post by BYOB Fishing »
I hope the previous owner was getting some compensation from Rapala and bass pro for all of that advertising...
'83 Bass Tracker Tournament TX 16.5'
'09 60hp Mercury Four Stroke EFI
'87 15' LOWE Pro Jon
'87 9.9 Evinrude
'06 Jeep GC
http://www.tinboats.net/forum/viewtopic ... 21&t=14064
manley09
Post by manley09 »
That is one sweet looking boat.
Saving for a Ranger bass boat...until then...
12' Alumacraft (V-hull) Build To Bass Boat!
MikefromSliderG5
Post by MikefromSliderG5 »
Looks like you did well for yourself! Very nice.
Mike
thatkidhugo
Thanks for the replies everyone.
I have finally gotten the courage and energy to start working on my boat. I will be completely stripping it down tomorrow, and I did a bit of a sketch on paint to get some feedback (good and bad, don't be scared :D) from you guys. Does anyone see anything that should be changed around? The space between the middle and back seat will just be carpeted and kept low. Both front and back decks will be framed with aluminum.. I could do it myself using wood but I'm just worried it will all be to heavy, so I found a welder that will do all the framing at a reasonable price.
Please, all comments are welcome. :D
thatkidhugo
After a long night.. a lot of smoking and just a bit of drinking she's finally stripped down. The previous owner did a piss poor job on the decking as you can see in picture 002.
Now its time to get her cleaned up and tested for leaks.
Wish me luck! :D
thatkidhugo
I had a day off from work today so I kept myself busy. I decided not to power wash just yet but to remove the transom and the old paint. Definitely not a easy task getting rid of 4 coats of paint. I bought a can of "Super Remover" which really made it a lot easier along with a wire brush and drill. As soon as I brushed this stuff on it immediately started to bubble up, great product. There is still a bit of red paint, but I'm sure a coat of primer will cover it up. Now it's time to weld some holes and start looking into marine paint.
Here is a link to the paint remover: https://www.homedepot.ca/product/paint-v ... tre/915717
Post by fool4fish1226 »
Good work, I like to see that you are making the boat your own, keep up the good work
Project "A Little Snookered" http://www.tinboats.net/forum/viewtopic ... 21&t=22132
thatkidhugo
No progress today, need to weld 14 holes where the old transom was.. yes, the factory put 14 screws in the transom! Looked around online for a aluminum welder and found a couple. The first guy I called wanted $250 to weld those holes... so I called another guy. I found one about 20 mins from my place and he's charging me $100 which I think is fair.
I've made up my mind and decided to use gluvit on the inside bottom of the boat right up to where the decking will start and use steelflex on everything else.
As for the decking, I've been looking at a lot of builds on here and I've decided to frame in aluminum. The thing is.. is it worth it to get all of my frame work welded? Would it be stronger then using rivets? I'm not comfortable doing everything in rivets.
thatkidhugo
My semi v sterling 1408 - UPDATED: 4/25/12
Here are some small updates..
I thought this would add a nice touch.
Rear end all plugged up (harharhar).. not sure if I'm going to use wood or plastic for the transom.
Plans change.<br /><br />Got rid of the middle bench seat and decided to go with a nice flat deck.
Plans change.
Cut out small portion of the rear bench seat to allow wiring for my radio.<br /><br />Prepping for paint SUCKS!
novaman
Post by novaman »
Great start toward a boat that's all done the way YOU want it. Nice work so far, keep it up =D> .
If something was done unorthodox, I might have had a hand in it, and then again I might have had the ONLY hands in it!
2004 Tracker Grizzly 1648/ 04 25 hp.Mercury 4 stroke http://www.tinboats.net/forum/viewtopic.php?t=24919
2008 Alumacraft 2072 w/Nissan 115 TLDI for push.
Wan2fly
Post by Wan2fly »
Great job on boat!!
Got a question. Did your boat have sand bags in the back seat of the u on either side? I have tha same boat and the sand bags inside the very back seat of the u on either side of boat and are broke with sand coming out of drain on boat.
The seat appear not to be modified.
Why are there sand bags in there anyways? What are their purpose and can they be removed?
Thanks
