Finding and patching/sealing a hole
DustinBecker
I thought I had found and plugged a small hole in my boat. Come to find out I was wrong. Any suggestions on the best way to pin point the leak and what to use to seal it?
Fill the inside of the boat with water... Just a inch or two. Look on the underside for leaks. For small holes most people use 3m 5200.
Where does everyone recommend applying the 3M 5200? Outside the boat, inside the boat, or both?
