14' Crestliner Viking refresh
Silverad04
Post by Silverad04 »
Yea know, there arnt near enough crestliners on this site!!! Starting with the trailer...
1958 14' Crestliner Viking 15 Mercury 4S viewtopic.php?f=21&t=33307
1969 14' Starcraft 15 Evinrude 4S viewtopic.php?f=21&t=38929
Silverad04
1958 Crestliner Viking build
The factory Gator trailor is turning out nicely
countryboy210
Post by countryboy210 »
Off To A Good Start !
Full Speed Ahead !
DrNip
Post by DrNip »
Yep, yep! Nice work space too!
Silverad04
Thanks fellas, I just finished the garage last month. I put up drywall, removed the crappy old work bench from the previous owner, and built the cabinets and new bench and painted everything. It was my first attempt at cabinets, not perfect by any means, but good enough for a garage. This was my first time working with oil based paints on a large scale, its soooo runny!!! Me and my buddy are going to do the second coat of primer tommorrow, and if all goes well, dark grey final coat next week. I have to order a whole bunch of bolts and hardware so I can put it back together.
-Rob
Pweisbrod
Post by Pweisbrod »
Looks good. My next boat will be a 19 crestliner. Something with a forward console, like an old Norseman.
lckstckn2smknbrls
Post by lckstckn2smknbrls »
Looks good.
Don't forget the site has a trailer section.
Silverad04
lckstckn2smknbrls » Today, 11:53 wrote:Looks good.
The subject of the post is the topic, the trailer is just a step in the rebuild, like sanding your hull before paint...
Silverad04
off to get its last coat of paint, I added the two side supports in the rear and got rid of the tilt functoion on the trailer. I also got rid of the front bunks and extended the rear bunks. I was worried about the front bunks rubbing off the steelflex epoxy when loading and unloading the boat.
Silverad04
I went and bought the materials for my aluminum transom. I got 1.5 x 1.5 square 1/8" tubing, and a sheet of 1/8" aluminum for the other side of the sandwich. I was planning on having the tubing welded up, and using the existing bolt holes from my wood transom, to bolt it back together. Does anyone see anything wrong with this plan?
Silverad04
well, progress is slow goin, but better than nothing. Do the seats look to high in the temp position? Should I lower them, ihas anyone had their seat this high?
jethro
Post by jethro »
Seat height looks good to me... are you putting a flat floor in the boat? Would be perfect height with a flat floor.
I fish, therefore, I am.
1993 Starcraft SF 14 DLX side console with 25 hp Mercury 2 stroke
2003 Sylvan 2100 Profish walkthrough with 150 Mercury Saltwater and 6hp Mecury 4 stroke kicker
Silverad04
jethro » 11 minutes ago wrote:Seat height looks good to me... are you putting a flat floor in the boat? Would be perfect height with a flat floor.
Yea im putting in a floor, but I sat on the seats and it seemed so high. Once I get the 3/4 inch flooring, carpet, and seat mount, I'll be sitting above, or close to the gunwal.
Silverad04
Also, if you look at my new transom, I've raised the height to 3.5 inches. This puts the total transom height at 20.5 inches, but the cavatation plate is still an inch or so below the hull. The motors a long shaft 20 inch according to the serial number. I know that the transom is slighly tilted, but should the transom heght be 20 inches or 21 inches? Its too late now either way, but I'm just curious. I'm hoping to gain some mph so I can make up for all the weight I'm adding, with just me before the modifications I could hit 22mph.
Silverad04
I've made the compartments so that I can remove the plastic containers for cleaning purposes. I also added the drain plug, I don't know if it'll work, but I'll find out when I take her on the test run.
