Alweld Repairs, Deck and Rail Install
Poormans Boatright
Post by Poormans Boatright »
Here's a project I recently completed for one of my customers.
Front was ripped open
He had these mounts on originally.
New skin across the ftont
My build: http://www.tinboats.net/forum/viewtopic ... 21&t=19816
I Pray that I May Live to Fish, Until my Dying Day.
And when it comes to my Last Cast. I then most Humbly Pray.
When in the Lord's Great Landing Net and Peacefully Asleep,
That in his Mercy I be Judged as Big Enough To keep.
Poormans Boatright
Moving onto the deck
He had these beat up braces on from a wood deck
Adding angle iron supports
Poormans Boatright
Continuing progress.....
Fiberboard will be used to make a pattern for the aluminum sheet.
Close but not perfect
Poster board is used to make a tighter pattern.
Cut n ready to trial fit
Poormans Boatright
Laying the deck sheet.
Piece fit pretty good, only requiring a little grinding here and there to fit.
A second pattern for the end caps
Completed deck
Completed deck
water bouy
3
Post by water bouy »
Nice job. Who did the welding.
16 ft Sea Nymph w/30 Johnson
14 ft Monark w/25 Merc XD sold
1994 Lowe 1605 w/50 Evinrude sold
14 ft Lone Star w/15hp Evinrude sold
Poormans Boatright
Water Bouy, I do all fabrication and welding.
Ok, I got time to post a few more pics.
Owner wanted the front rail to be removable, so I made thes 1/4" thick pads so the upright rail can weld to and bottom be drilled and tapped for bolts.
Using a tap
Using a tap
Time to use the bender
First rail hoop bent
Mid rail going in
Mid rail going in
Back braces in
Back braces in
Poormans Boatright
Continued.....
Complete
Complete
Back mount
Back mount
Front mount
Front mount
A few different views of completed front rail
Post by richg99 »
As always, great work. richg99
Poormans Boatright
Thanx, Rich
stomper
6
Post by stomper »
Looks great. Can'y wait to see the finished product. I like the all aluminum builds. Are you mig welding it or tig welding. What are you using for the framing, looks like angle. Is it 2x2x.125 or 1.5x1.5x.125?
Poormans Boatright
Stomper, the angle is 2 x 2 x 1/4, The sheet is .125, I use both mig and tig, mostly tig though.
