Tapatalk has been disabled due to being incompatible with the current version of the forum software. Will be re-enabled once it's fixed.
MID 1980'S 14 FOOT SMOKERCRAFT BIG FISHERMAN
derekdiruz
5
Post by derekdiruz »
For waterfowl I like the deck ideas. I'd install pedestals on the floor between the benches if that's going to be hunting from the boat. But if it's transport I'd be sure to just incorporate a hatch in the front big enough for your blind bags that is relatively water tight. Enough so the rain stays out. Otherwise covering the gas tank and battery in the rear is smart too. With my boat I just bought for waterfowl, a friend is welding the brackets for a rear deck. The same with a front deck. The front doesn't have a hatch though and just has it open below. The rear is hatched for gas tank and battery, and he middle bench is hatched as well. Floor has 3 pedestals to hunt from. I find this manner to be a perfect blend for fishing and hunting.
Sent from my SM-G930V using Tapatalk
water bouy
3
Post by water bouy »
I want your boat. At some point could you see if the two struts running down the middle of the floor are the same height on each end? When I look at the front of mine it's hard to tell what's level even when I lay something across all the benches.
I talked to a Smokercraft dealer today and he said manufacturers didn't use marine plywood back then.
16 ft Sea Nymph w/30 Johnson
14 ft Monark w/25 Merc XD sold
1994 Lowe 1605 w/50 Evinrude sold
14 ft Lone Star w/15hp Evinrude sold
Bubba8018
3
Post by Bubba8018 »
Well....I'm back at it. Boat is gutted and I am prepping for paint. Looking for a process that will be durable and cost effective?? Do I need to prime?? What kind on paint to buy, etc.
