It is currently 19 Apr 2019, 06:26
 Page 1 of 1 [ 8 posts ]
PostPosted: 25 Nov 2016, 19:20
Hello guys... I have a 1984 Bass Tracker 2 and it is in need of a facelift (new deck new paint etc.) I have already started removing pieces but I am stuck at removing the livewell/seat's has anybody here had any experience in removing livewell/seats before?
PostPosted: 25 Nov 2016, 19:41
are they factory installed or aftermarket by some P/O?
what part are you having trouble with ?
the physical removal process - or -
removing them completely to put in your new floor.
http://www.tinboats.net/how-to-build-a-transom/
http://www.tinboats.net/varnish-vs-polyurethane/
All about Primers = http://www.tinboats.net/primer-and-paint-basics/
Paint, Thinners and Applications = http://www.paintingforpainters.com/
1959 Lone Star Malibu 14'
PostPosted: 25 Nov 2016, 20:00
They are the original and never removed to my knowledge the boat was my grandfather's... I am wanting to remove the entire livewell/seat. They are not riveted down and I'm assuming they just pullout but I can't seem to get them to move...
PostPosted: 25 Nov 2016, 20:16
There has to be some hidden rivets or screws somewhere. Is the livewell plumbing disconnected? Also is there any foam under there that they might be sticking to?
1994 Spectrum Dominator16 Mercury 25HP 2 stroke Minn kota Edge 45 and Minn Kota Endura Max 55
PostPosted: 25 Nov 2016, 23:23
I went ahead and peeled back the aluminum siding which I was trying to avoid and found the livewell's are actually welded in at the fill pipe.. #-o I appreciate all the quick replies...
PostPosted: 27 Nov 2016, 20:02
i used to own the same boat... as you stated my live wells were welded to the fill/drain tubes and without cutting them there was no way to remove. I left them where they were and built around them. you can check out my build or feel free to ask any questions..
"Bass Tracker III." in my signature
Bass Tracker III
viewtopic.php?f=21&t=29582
Delhi, 12ft "Buckshot"
viewtopic.php?f=21&t=26077&p=267559#p267559
Delhi, 1430
viewtopic.php?f=21&t=26966
Lowe 1436 with Yamaha 15 (Buckshot's Big Brother)
viewtopic.php?f=21&t=26833
PostPosted: 27 Nov 2016, 23:00
Thank You I will probably take you up on that offer... Did you have a forum going for your rebuild??
PostPosted: 29 Nov 2016, 20:41
[/quote]Thank You I will probably take you up on that offer... Did you have a forum going for your rebuild??[/quote]
yes i do... check my "signature" for all of my builds but here is the direct link to my old bass tracker:
Bass Tracker III
Delhi, 1430
Users browsing this forum: No registered users and 45 guests
akmccallumco
