1987 Alumacraft V16 DLX Rebuild
Lost
3
Post by Lost »
After wanting a boat for my entire life, I finally found a "project" boat that I could afford. The seller claimed that the floor was only getting "soft" and could still be used, but his policy of storing outside for the past couple years without a cover proved to be too much for what was left. Thankfully I found this forum while reading about how to fix it, and decided to actually start a thread to document my progress with the project.
Seller's Photo
Seller's Photo
Seller's Photo
Seller's Photo
Seller's Photo
Seller's Photo
Seller's photo
Seller's photo
1987 25HP Mercury
Re-build: https://www.forum.tinboats.net/viewtopi ... 21&t=43184
Lost
3
Post by Lost »
Shortly after getting it home, I began the process of cleaning everything out and removing all the old wood & carpeting. Had to take measurements of everything as the floor pieces were held together by only the carpet.
1987 25HP Mercury
Lost
3
Post by Lost »
After getting the floor pieces up, I began the process of removing the nasty water-and-who-knows-what-else logged foam.
1987 25HP Mercury
Lost
3
Post by Lost »
As I read more in these forums, I began to get concerned about the transom. Upon further investigation, I decided that I needed to pull that too. Good thing I did, as the lower corners literally fell off as I picked it up to make a template.
Investigating the lower corner
Investigating the lower corners
Transom out
Transom out
Rotten corner
Rotten corner
Rotten corner
Rotten corner
1987 25HP Mercury
Lost
3
Post by Lost »
Next steps are to scrub out the rest of the boat, check for leaks, seal with gluvit since the floor is out, rivet in some additional aluminum framing to increase floor support (I'm a big guy and wanted some extra support for the 1/2" floor), get marine plywood and start cutting new pieces for the floor/sides/transom, seal the pieces, get carpeting on the pieces, and re-install everything. Turning out to be a lot more effort than I initially had thought it would be, but at least I will know the boat inside-and-out and it should last another 30+ years.
I'll also be running new wires for the lights and adding a fuse block and switch panel for any accessories that I want to add.
1987 25HP Mercury
DaleH
5
Post by DaleH »
Lost wrote:Next steps ... seal with Gluvit since the floor is out ...
IMHO West Systems G-Flex 650 is the better choice on any areas subject to stress ... as it is flexible. One key area is that area 1/3rd back from the bow, as that's where a boat typically hits the waves. I've seen a TON of boats in my life with stress and/or fatigue cracks localized in this area.
See: https://www.forum.tinboats.net/viewtopi ... =3&t=40954
mrdrh99
5
Post by mrdrh99 »
Great job so far! You'll be so much happier knowing that you took it bare bones and fixed everything, especially that transom!
Eat, drink, and be merry, for tomorrow we die
Lost
3
Post by Lost »
Well, after doing some cleaning and filling it with water, I have discovered that the supposedly not-leaky boat has leaks! So now I get to seal. DaleH, I'll look into G-flex, but I think I will start with the Gluvit since I already have it on hand.
Was marking with yellow tape, then switched to a marker
Pretty good leak coming from up towards the front
1987 25HP Mercury
1986Landau
5
Post by 1986Landau »
Congrats on the boat! I have the same thing minus the fact that the previous owner removed a bunch of the original equipment etc. I can't wait to see where you go with this! Mine is going to be a very open floor plan with lots of pedestals for the kids, myself and maybe my dad on occasion. Keep up the good work!
Lost
3
Post by Lost »
The work continues. Boat is sealed with no leaks and I started adding in my extra supports. Manual riveter decided to stop working after 6 rivets so that's going back to amazon and I've already replaced it with a pneumatic one. Should have done this initially, as it makes riveting a breeze.
My assistant
My assistant
Supports being fitted
1987 25HP Mercury
water bouy
3
Post by water bouy »
That's gonna be a nice boat. It appears it only had one stringer in the middle to support the floor? Seems like they usually have two.
16 ft Sea Nymph w/30 Johnson
14 ft Monark w/25 Merc XD sold
1994 Lowe 1605 w/50 Evinrude sold
14 ft Lone Star w/15hp Evinrude sold
Lost
3
Post by Lost »
It just has the one. The original floor rested on the stringers at the edges and on the single center support.
1987 25HP Mercury
DuraCraft
Post by DuraCraft »
Looking good, lost. I like to see them taken all the way down to nothing left but boat, real boat. All that wood and foam mess out, then you can do it right. Like they say, I think it's got good bones.
Coffee and water mix real good...
I ain't the slickest eel in the crick.
I like >))))))):> Ummm good.
You are = you're, i.e., You're doing a good job.
Your = possessive, i.e., That is your boat.
"I thought I was wrong one time, but I was mistaken". Command Sargeant Major J.D.
Lost
3
Post by Lost »
Flooring supports are in and I'm finally starting to cut the new decking pieces. Floors are 1/2" while all the compartment lids/tops will be 3/4" (just copying what it was originally). I've also ordered some hatches that I can install to gain more storage space, which will allow me to utilize the side chambers of the front bench for storage, leaving the center for the dual battery setup I want to have for the bow trolling motor.
1987 25HP Mercury
Lost
3
Post by Lost »
One more piece to cut for the floor and then I can start on all the hatch/trim pieces.
1987 25HP Mercury
