Princecraft Yukon 15
ProduceMan
5
Post by ProduceMan »
A tip I got from this sight, use heat-shrink tube on your foil's bolts.
1973 Hewescraft Big Fisherman 14
1980 Johnson 15
“I love being alive and will be the best man I possibly can. I will seek knowledge from those wiser than me and try to teach those who wish to learn from me.” Duane Allman
TheLastCall
2
Post by TheLastCall »
So it’s been a while since I’ve had the opportunity to update my build.
I’ve been away for work for the last 4 1/2 months. Work keeps getting in the way of my hobbies.
I got the electrical panel sorted out and put back in. It’s raised off the bottom on the boat by almost 3 inches so even if I do get water in the boat I don’t worry about it.
All the benches are back in, for now.
I got a Garmin Striker 5cv to put in the boat. To mount the transducer I used a 1 inch cutting board bolted on the transom. Worked amazing. Now I can move or add transducers as needed without drilling new holes. I mounted the unit across for where I sit ( I don’t care for it there more on that later)
So I got the motor back on the boat, went to start it and ... nothing. I ended up having to rebuild the carburetor, old fuel gelled in it.
So I’ve had it out a few time now and figured out what I like and why needs to change, I’ll start with the likes;
- the hydrofoil, it has cut my bow rise by more than half. The boat gets up on plane really fast and it will stay on plane at 1/2 throttle.
- the scotty mount on the stern are great for keeping rods away from the kids, and clears up space in the boat
- the new battery location and securing fuel tank. Again it cleared clutter in the bottom of the boat. I also put it opposite to where I sit so it evened out the weight.
Now for the dislikes;
- fish finder location. I find I’m looking down at it more then I should so I’ll be moving it to one of the oar locks so it’s closer to me when fishing from the front and up a little when moving.
- fish finder. Don’t get me wrong I love the unit and it’s great quality but the gps function is useless to me the lakes here are all fairly small and generally I fish the same lake over and over so I know where things are and don’t need a gps.
- no storage. All my gear is kept in milk crates so it’s easy to move around but I want something more permanent so I don’t have to move it around.
- I need a trolling motor. Where I fish smaller lake running my outboard is like a siren for the fish. And the lakes here are all shallow ( 25 ft deepest), I’m usually fishing in less than 5 ft of water. Running a trolling motor will save my outboard.
TheLastCall
2
So here is the plan for the future, when I get more funds. The boat is very stable so I’m not concerned about the raised deck. I might add a seat near the bot but I’m still undecided. [ external image ]
